Postby jdebord » Fri Dec 14, 2018 9:56 am
After a short interruption (apparently due to the change of title) these magazines are distributed again in France.
Now we have issues 15 and 16 which add 8 flat plates to the previously built frame:
The central part will be covered by the roller bearing which will allow the rotation of the boom.
In the magazines:
* History of Meccano Supermodels : Railway breakdown cranes
* History of Meccano parts : electric motors / screwdrivers
* History of Meccano : Mogul (metal toys)
* Other models
Postby Mark » Fri Dec 14, 2018 12:42 pm
Is the blue correct for the period? I remember it being a much deeper blue, but perhaps it’s the photo, or my memory ;)
It’s coming on nicely :D
Postby jdebord » Sat Dec 15, 2018 8:59 am
Yes, it's the photo ! The plates are rather dark blue.
Postby Mark » Sat Dec 15, 2018 2:26 pm
Glad they did get the colours right.
Postby jdebord » Fri Dec 21, 2018 8:55 am
Issue 17 is available.
It adds four 25-hole angle girders to the previously built structure:
In the magazine:
* History of Meccano parts : The high voltage motors of the 1920's
* History of Meccano : The beginning of the zinc period: Meccano Tri-Ang and Meccano France
* Other models
Postby wingnut2 » Fri Dec 21, 2018 5:10 pm
Hi, it's beginning to take some shape, great pics too :clap: .
Postby jdebord » Fri Dec 28, 2018 8:41 am
Issue 18 is available.
It adds two 25-hole angle girders (A) to the basis of the previously built structure.
On the top of the structure it adds four 9-hole angle girders (B); each angle girder holds an angle bracket (C).
In the magazine:
* History of Meccano : Electric kits of the 1920's
* History of Meccano parts : The 1.5" pulley
* Other models
There will be a two-week interval between issues 18 and 19. In the meantime I wish you a happy new year :)
Postby jdebord » Thu Jan 17, 2019 9:12 am
After a short interruption, Issues 19 and 20 are available.
With these issues you get 2 important parts:
- a U-shaped ring (issue 19)
- a toothed plate (issue 20)
Both are about 30 cm in diameter and are very well packaged, each one having its own plastic case.
I have not yet begun the assembly of these parts, so I will describe it later.
In the magazines:
* History of Meccano : The nickel period / Meccano motors from 1937 to 1948
* History of Meccano parts : Roller bearings
* History of Meccano models : Railway breakdown cranes
* Other models
Postby Mark » Thu Jan 17, 2019 12:39 pm
I never realised that Meccano made parts that big!
Postby chill » Thu Jan 17, 2019 1:50 pm
Wow some serious civil engineering type componants going on there!!! :shock:
Postby jdebord » Fri Jan 18, 2019 9:45 am
It is derived from the Geared Roller Bearing (GRB) that Meccano made for this type of cranes:
http://internationalmeccanomen.org.uk/R ... B/grb.html
Now a replica costs about 300 euros !
Postby Mark » Fri Jan 18, 2019 10:45 am
Ouch! That’s an expensive replica!
Postby jdebord » Mon Jan 21, 2019 9:18 am
Here is how the parts from issues 19-20 are linked together.
On the upper side, the U-shaped ring is linked to the toothed plate by 8 angle brackets; each angle bracket is separated from the toothed plate by two washers.
On the lower side, we have another 8 angle brackets, mounted on the same 9.5-mm bolts than the previous ones.
A 9-hole angle girder is then bolted to each angle bracket. Note that 4 of these angle girder / angle bracket pairs are taken from the tower top (issue 18).
There is still another part to add (a bush wheel) but the instructions do not mention it, so I wait till the next issue.
This assembly will then be bolted to the tower top.
It's a bit tricky but all in all, it's a very nice build :)
Postby jdebord » Sat Jan 26, 2019 9:06 am
Issue 21 is available.
With this issue we place a bush wheel in the center of the toothed plate. We can then link the plate to the tower top by bolting the 9-hole angle girders to the blue plates.
In addition, we prepare some parts belonging to the pillars of the crane:
In the magazine :
- History of Meccano : French production sites in the red/green period
- History of Meccano models : Shooting stands
- Other models
Postby jdebord » Fri Feb 01, 2019 9:13 am
Issue 22 is available.
It contains the same parts than issue 21 and also builds two elements of the crane pillars, but with a slightly different placement of the 3-hole and 19-hole angle girders:
In the magazine :
- History of Meccano parts : Bush wheels
- History of Meccano supermodels : Steam excavator
- Other models
Postby jdebord » Thu Feb 07, 2019 8:48 am
Issue 23 is available.
The two crane pillars are connected to the previously built structures.
Here the assembly is pictured upside down, and with the bogies removed:
In the magazine :
- History of Meccano : Meccano in the classroom
- History of Meccano parts : Motors of the 90's
- Other models
Postby Mark » Thu Feb 07, 2019 12:48 pm
Its already looking big!!
Postby jdebord » Tue Feb 12, 2019 9:12 am
Here you can see the comparison between the Hachette crane (first picture) and the Super Model 4 (second picture) :
http://meccano.free-bb.fr/sujet-640585- ... eante.html
Postby jdebord » Fri Feb 15, 2019 9:12 am
Issue 24 is available.
It builds 4 additional pillar elements, just like issues 21 and 22.
In the magazine :
- History of Meccano : The Meccano X system
- History of Meccano models : Motorcycles
- Other models
Postby jdebord » Thu Feb 21, 2019 8:59 am
Issue 25 is available.
It builds the other side of the crane tower :
In the magazine :
- History of Meccano : Meccano Wide Beam
- History of Meccano parts : Screwdrivers
- Other models
