Airfix Engineer Combustion Engine
Here's a little section of anybody who manages to find a really odd ball model that doesn't fit into any of the other catergories.
Postby Paul » Sat Dec 15, 2012 2:33 pm
I went for a browse in my local model shop this morning and saw the Airfix Engineer Combustion Engine, and just had to get it !!! :D
More details and pics up later ! :)
Re: Airfix Engineer Combustion Engine
Postby Mark » Sat Dec 15, 2012 2:42 pm
Ah, one of those models that I always wanted. I also fancy the paddle steamer engine they re-issues.
I'll look forward to seeing this one Paul. It''s an old tooling, so should give you a few challenges.
Postby Paul » Sat Dec 15, 2012 2:51 pm
Mark wrote:Ah, one of those models that I always wanted. I also fancy the paddle steamer engine they re-issues.
Hi Mark, apparently no :superlglue: or paint required, though on the latter I think it will be modded !!!!! :)
Postby Paul » Sat Dec 15, 2012 2:59 pm
It features light and sound and apparently, first the engine 'starts up' and then it runs 'firing' to show how the combusting fuel and air drives the pistons down to make the crankshaft turn.
Postby Paul » Sat Dec 15, 2012 3:15 pm
As is now customary on the forum, pics of the front and back of the box and then parts will follow.....
Postby Paul » Sat Dec 15, 2012 3:16 pm
A pic of the front of the box:
Postby Paul » Sat Dec 15, 2012 3:17 pm
And a Pic of the Back of the box:
Postby Paul » Sat Dec 15, 2012 3:18 pm
Finally a general pic of all the parts
Postby Paul » Sat Dec 15, 2012 3:47 pm
I forgot to add the parts list, :oops: :oops: :oops:
So they are included below:
Postby Mark » Sat Dec 15, 2012 4:20 pm
Ah, different kit to the one I was thinking of. I built the Haynes version of this with my daughter. Assuming it's the same tooling, it goes together quite well.
Postby Paul » Sat Dec 15, 2012 5:59 pm
Mark wrote:Ah, different kit to the one I was thinking of. I built the Haynes version of this with my daughter. Assuming it's the same tooling, it goes together quite well.
Hi mark , I started spraying certain parts, yet have now seen that the parts need cleaning up :oops: :oops: :oops:
Postby morrigan » Sat Dec 15, 2012 7:22 pm
Oooh very nice find Paul :D
Must say I like the look of the jet engine to.
Hmmm more stuff for the wish list. :lol:
Postby Paul » Sat Dec 15, 2012 7:34 pm
morrigan wrote:Oooh very nice find Paul :D
It's def going to be painted !!!! :) :) :)
Postby Mark » Sat Dec 15, 2012 11:06 pm
It should look good with a lick of paint, but depending on what bits you paint, you might not be able to see the working innards.
The sound module on mine is not very loud. It's almost drowned out by the noise from the motor.
Postby baby_astons » Sat Dec 15, 2012 11:22 pm
maybe you could paint one half and leave the other side transparent to show the moving parts...
Postby casper » Sun Dec 16, 2012 12:57 am
Great looking kit Paul .
I remember seeing the haynes version built for display in modelzone.
Look forward to seeing it go together. :mrgreen:
Postby Paul » Sun Dec 16, 2012 10:22 am
baby_astons wrote:maybe you could paint one half and leave the other side transparent to show the moving parts...
That's the plan :)
Postby Paul » Sun Dec 16, 2012 11:16 am
Hi Mark,
The tooling looks new from the parts.
This model is 240mm long by 220 high, including the base
Postby Paul » Sun Dec 16, 2012 11:18 am
Hi Morrigan,
Yes, I think the jet engine will be a must at a later date :)
Postby Paul » Sun Dec 16, 2012 11:22 am
The fan was supplied black, so that is in the process of being sprayed red.
The pistons and rods were white, but I've sprayed then with Humbrol chrome silver 191.
For the crankshaft, which was black, I'm now spraying it with Humbrol aluminium 56
Return to Miscellaneous Models
