1848 Stage Coach
Here's a little section of anybody who manages to find a really odd ball model that doesn't fit into any of the other catergories.
Re: 1848 Stage Coach
Postby Mustang » Mon Jul 22, 2019 3:15 pm
casper wrote:wonder how many hubs get sent back :think: Are they MDF Ian
Hi Mark, there made from hardwood from the looks of them.
Postby Mustang » Tue Jul 30, 2019 4:55 pm
Pull bar, the end had to be sanded down to this shape.
Postby Mustang » Tue Jul 30, 2019 5:00 pm
This is the start of the front axle unit for steering.
The main unit is made up from four pieces of wood which again has been painted yellow on the side, will update once the paint has dried.
There is also the brass piece which get added once dry, the strange shape piece is for the draw bar and had to be shaped by hand and also the other brass bits where cut from 4mm wide stripes and then shaped.
The two square pieces have had there ends soldered, the instruction say to leave as they are or paint black but I'm thinking off tarnishing them to look old.
Postby Mark » Tue Jul 30, 2019 6:06 pm
Nice neat work Mustang :clap: :clap:
Postby Mustang » Thu Aug 15, 2019 6:18 pm
Cheers Mark.
Brass sections added.
Postby Mustang » Thu Aug 15, 2019 6:21 pm
Next was to make upper the lower and upper axle parts.
In the lower axle part I had to cut out the sections to allow the rest of the unit to sit into the axle.
Postby casper » Thu Aug 15, 2019 6:25 pm
Great work Ian, like the brass work :clap:
Postby Mustang » Thu Aug 15, 2019 6:26 pm
Little filling and sanding all good.
Postby number1 » Thu Aug 15, 2019 10:45 pm
Excellent fit of the woodwork joining :clap: :clap:
Postby Mustang » Sun Sep 01, 2019 9:41 pm
Thank you Number1.
Postby Mustang » Sun Sep 01, 2019 9:44 pm
More brass work added.
Postby Mustang » Sun Sep 01, 2019 9:47 pm
This piece is to be shaped into the pull bar which is used to connect the horse to the wagon
After some time sanding.
Brake unit.
Postby Mustang » Sun Sep 01, 2019 9:50 pm
Part all coming together.
Axle fitted.
Dry run to see how it would look, and its BIG
Postby casper » Sun Sep 01, 2019 10:18 pm
You get a much better idea of scale now Ian and she's a lot bigger than I thought. Very neat work and the brass looks great :clap: I like the yellow as well it goes perfectly with the wood.
Postby Mark » Mon Sep 02, 2019 5:22 am
Looking very impressive Ian. Very neat work.
Postby BigG » Mon Sep 09, 2019 8:12 pm
Excellent work . I am building this model at the minute. What colour of yellow did you use for the wheels?
I CAN RESIST EVERYTHING EXCEPT TEMPTATION
BigG
Postby Mustang » Tue Sep 10, 2019 4:16 pm
Thanks guys for looking in.
Postby Mustang » Tue Sep 10, 2019 4:18 pm
BigG wrote:Excellent work . I am building this model at the minute. What colour of yellow did you use for the wheels?
Hi BigG the paint I used is Lemon Tropics just a small sample pot from my local hardware store.
Postby Mustang » Sat Sep 14, 2019 11:05 pm
Break handle.
I added an extra little piece to the end handle.
Return to Miscellaneous Models
