Tigerace`s Akagi
DeAg's Japanese aircraft carrier.
Re: Tigerace`s Akagi
Postby tigerace » Sun Nov 08, 2015 7:59 pm
ok guys update have completed the bow and middle lifts also painted the hanger parts and the first coats of primer on the hull Image Image Image Image Image Image Image cheer`s thank`s for looking in :D
tigerace
Postby steve131 » Sun Nov 08, 2015 9:51 pm
Nice work, what primer you using :?: ,used to seeing gray
Postby Eric » Sun Nov 08, 2015 11:21 pm
Your hull work looks excellent tigerace, keep up the good work!!
Postby tigerace » Mon Nov 09, 2015 6:18 pm
Thanks Steve and Eric i`m using the Halfords filler primer first then i`ll use the grey to finish the priming then the hull colour`s :D
tigerace
Postby Gundog » Mon Nov 09, 2015 8:19 pm
Used the same stuff on my Bismarck hull. Works well, but the colour leaves something to be desired.
In the stash: Way too much
Gundog
Postby tigerace » Sun Nov 15, 2015 2:19 pm
yeah your right good paint but whole new meaning of banana boat :laughing-rolling:
tigerace
Postby tigerace » Mon Nov 16, 2015 1:40 pm
Ok guy`s built and painted the lift`s Also fitted the bilge keel`s 8-) Image Image Image Image
tigerace
Postby Eric » Tue Nov 17, 2015 12:41 am
Looking good tigerace.
I take it these lifts are non operational? It would be nice if they worked.
Postby tigerace » Thu Nov 19, 2015 1:42 pm
cheer`s Eric no lift`s don`t work i`m afraid would have been awesome though :D also realised when the lift platform`s are in place you won`t be able to see the motor`s etc :angry-banghead:
tigerace
Postby tigerace » Fri Nov 20, 2015 1:40 pm
Ok test fitted the hangers on the hull no real problems just some adjustments to the tabs to get them to fit better also painted the hull grey no more banana boat :laughing-rolling: Image Image Image Image Image Image Image Image Image thanks for looking in 8-)
tigerace
Postby number1 » Fri Nov 20, 2015 5:10 pm
Hulls looking really good, hope my Hood hull turns out just the same :clap: :clap: :clap:
Postby tigerace » Mon Dec 07, 2015 4:30 pm
hi everyone built up the inner trays plus fitted and glued hanger`s also built up the lift platrorms :D Image Image Image Image Image Image Image Image Image Image Image Image Image thanks for looking in 8-)
tigerace
Postby tigerace » Sat Dec 12, 2015 2:44 pm
Well i`ve driiled all the portholes and pack 15 has arrived first etch deck plate which is for the bow and lot`s of strip for the degausing line....Have you noticed i`ve not built up any of gun platforms as they will need adjustments before being attached also i`m not building the planes until last :D Image Image Image Image Image Image Image Image Image Image Image THANKS FOR LOOKING IN 8-)
tigerace
Postby Eric » Sun Dec 13, 2015 3:48 am
That is a LOT of superstructure piled onto the original hull, this carrier must have had some stability problems in real life!
Postby tigerace » Mon Dec 14, 2015 2:45 pm
Not sure about the Akagi? i no she was one of the fastest carrier`s after her refit though,i can`t find any reference to say she was unstable :angry-banghead:
tigerace
Postby Eric » Tue Dec 15, 2015 1:39 am
I'm not sure either Tigerace, but I do know that most of the Japanese cruisers were very tender, especially the Mogami class ones, as were their destroyers so it wouldn't surprise me if she was a bit unstable!
Postby tigerace » Tue Jan 12, 2016 1:40 pm
She was laid down at the Kure shipyard as an Amagi-class battlecruiser but no mention of any problem`s with stability?
tigerace
Postby Gundog » Tue Jan 12, 2016 3:14 pm
I read somewhere that she wasn't overtly unstable, but that removal of much of the armour did improve her seagoing characteristics. Unfortunately, the down side was that it made her vulnerable to air attack, as she found out at Midway.
Gundog
Postby tigerace » Fri Jan 22, 2016 1:50 pm
Ok guys here`s where i`m up to degaussing strip added along with work on the island ,funnel.and interior also brass bits added to bow and forward hanger along with pack 16 arriving can paint the rear deck too :D Image Image Image Image Image Image Image Image Image Image Image Image Image Image ImageImage
tigerace
Postby tigerace » Sun Jan 31, 2016 6:29 pm
okay painted the rear deck and built up the island painted the hull Image Image Image Image Image Image thanks for loo :D king
tigerace
Return to Akagi
