Kyosho Hummer H1 by deagostini
Any Radio Controlled model partwork series.
Postby dus » Sun Jan 25, 2015 1:21 pm
Hi all i will be building this car/truck/monster and wanted to know
if you would like me to post photos of the build as i go along as there is no other full post on this topic
i had ordered part one over the crimbo period (silly me)
it hadn't arrived so i emailed deagostini and degaostini said it might of got lost in the silly seasons post and they have sent it out again
so just waiting on it to arrive hopefully it will be soon
http://scaletrucks.bb3host.com/index.php
I haven`t lost my marbles they on EVIL BAY
Hard work has a future payoff. Laziness pays off now
heaven didnt want me hell was afraid id take it over
dus
Re: Kyosho Hummer H1 by deagostini
Postby davetwin » Sun Jan 25, 2015 1:27 pm
Hi Dus,
It would be great to see your build of this 8-)
davetwin
Postby Mark » Sun Jan 25, 2015 3:15 pm
I'd love to see your build diary too :D
Postby dus » Mon Jan 26, 2015 5:01 pm
hi all
box 1 and 2 arrived today so i have the first 8 parts to the build
part 1
part 2
part 3
part 4
part 4 open
part 5
part 5 open
part 6
part 6 open
part 7
part 7 open
part 8
part 8 open
dus
Postby casper » Mon Jan 26, 2015 5:19 pm
Nice pics dus :) look forward to reading through your diary
Postby dus » Mon Jan 26, 2015 6:36 pm
hi casp thanks for the comment
im not 100% sure weather to wait and do photos of the the parts in the bags as above as they come in
or start to do the build and photo the bits as they go together
dus
Postby casper » Mon Jan 26, 2015 8:40 pm
dus wrote:hi casp thanks for the comment
I opened some of my Honda parts to get better photos and re-bagged them after to keep them safe but its up to you matey :)
Postby dus » Mon Jan 26, 2015 9:19 pm
I took them out of the main bags just for the photos then put the parts back in the bags with the numbered paper tops
part of me wants too start the build but the other parts says leave it
Like I did with the bycmo and nitro racer deagostini did years go
dus
Postby dus » Thu Feb 05, 2015 2:29 pm
hi all had a"VISIT" :( yesterday from ""BOREDOM AND IMPATIENCE" (i really hate them guys :lol: :lol: :lol:)
i wanted to play lets do nothing and they wanted to play lets build the hummer well they won (two against one and all that :lol: )
this is how far i got with the 8 issues
(note all body parts to be glued and decals to be fitted wont be glued or fitted until a later due to not knowing if im going to paint it or keep as is )
PART 1
46t gear,gear holder and screws
assembled
front grill and grill mesh
assembled
end of part 1
PART 2
hood and radiator cover
hood and front grill assembled
hood front grill and radiator cover assembled
hood front grill radiator cover and hood hooks assembled
air filter gasket assembled
air filter
assmebled
end of part 1 and 2
PART 3
wheel 1 and tire assembled
assembling servo saver
stopper servo saver upper arm and 3mm nut
servo saver adjuster servo saver shaft and lower saver arm
upper and lower saver arms and shaft
upper and lower saver arms saver shaft and spring
assembled
left upper and lower servo saver
assembled
left and right servo savers
air filter
assembled
air filter and air pipe
assembled
end of part 1 2 and 3
PART 4
bagged parts
left and right mirrors
left and right mirrors with arms
end of part 1 2 3 and 4
PART 5
bagged parts
bearing differential case and cup joint part 1
differential case cup joint and o ring
differential case cup joint o ring and 6 x 12mm shim
differential case cup joint o ring 6 x 12mm shim and 2.5mm x 10.3mm pin
differential case cup joint o ring 6 x 12mm shim 2.5mm x 10.3mm pin and 20t bevel gear
differential case cup joint o ring 6 x 12mm shim 2.5mm x 10.3mm pin 20t bevel gear and 2 10t gears and bevel gear shaft
assembled (bit of grease )
end of part 1 2 3 4 and 5
PART 6
bagged parts
bearing and differential case part 2
bearing differential case cup joint and o ring 6 x 12mm shim 2.5mm x 10.3mm pin
bearing differential case cup joint o ring pin shim and 43t gear joined to (differential case cup joint o ring 6 x 12mm shim 2.5mm x 10.3mm pin 20t bevel gear and 2 10t gears and bevel gear shaft) part 1 assembled Image
end of part 1 2 3 4 5 and 6
PART 7
bagged parts
pre-assembled driveshaft with 2 bearings
pre-assembled driveshaft with bearings and cup joint with grub screw
lower rear bulkhead differential and driveshaft (and a bit of grease)
lower rear bulkhead differential driveshaft and upper bulkhead assembled
end of parts 1 2 3 4 5 6 and 7
part 8
bagged parts
completed rear diff and lower rear suspension plate holder
completed rear diff and lower rear suspension plate holder oppersite end
rear shock tower with 2 3 x 12mm screws and 7.8mm flange balls
completed rear diff lower suspension plate holders and rear shock tower assembled
end of part 1 2 3 4 5 6 7 and 8
well thats it for now next batch due in march :( :cry:
hope you enjoyed seeing the progress so far
dus
Postby Mark » Thu Feb 05, 2015 2:46 pm
I love it when Lets Play takes common sense and gives it a wedgie :laughing-rolling: :laughing-rolling: :laughing-rolling:
Love the build diary. Can't beat lots of pictures :D
It looks like a really big and chunky model. Looks really good quality too. That servo saver is the bees knees !
(Hmmm.... Getting excited by a servo saver - perhaps I should get out more :lol: )
Postby dus » Thu Feb 05, 2015 7:31 pm
Mark wrote:I love it when Lets Play takes common sense and gives it a wedgie :laughing-rolling: :laughing-rolling: :laughing-rolling:
Hi mark thanks for that
but will you still be saying can't beat lots of pictures in 15 months time when all is finished lol
Maybe I could drag it out longer by only putting one small part together each week lol
dus
Postby Andrewyzfr6 » Fri Feb 06, 2015 11:52 am
Reminds me of the kyosho 1/10th kits i built as a teenager. the parts look verysimilar in style etc
Postby dus » Fri Feb 06, 2015 3:18 pm
Hi Andrew which kyosho kits are you talking about the standard kits out the box or the astra from deagostini??
dus
Return to R/C Models
