How to upload a Photo/Pic to the Forum
Useful info about the board, and some answers to FAQs
Postby Paul » Tue Oct 04, 2011 1:09 pm
Hi All,
How to upload a photo/pic to the forum, is quite often asked by our newer members.
There are two main ways of doing it:
• Upload straight to the forum.
• Upload using another on-line facility (there are plenty of free ones available).
Uploading straight to the forum
Pros:
• Easy and quick to do
Cons:
• Not very easy to determine the file size to use if added straight in rather than in-line.
• If you hit a certain level of storage on the forum, then you’ll need to delete earlier ones, before you can add new ones.
Pros:• No need to delete any photos off the forum if you hit the limit
• Easy to share with other on-line applications
Cons:• You have to up-load the photos to the on-line facility and then to the forum
On this thread, I’ll add more posts to explain how to do the above (with pics).
Kindest Regards
:text-worthless:
Postby Paul » Tue Oct 04, 2011 2:59 pm
Either start a new post, or reply to one
You can either:
• Attach a photo/pic
• Place a photo/pic in-line
In both cases, click on the "Upload Attachment" Tab
By the "Filename" click on "Browse" to locate the file you want to upload (you can add a fie comment if you want).
Then click on "Add The File", when this has happened, you then have 4 choices:
• Place inline (this will add it within the text)
• Delete
• Preview
• Submit
If you click the submit button then the file will be added as an attachment.
If you click the place in line button, the photo/pic will be within the text on your post:
An example of the photo/pic/file placed inline:
Re: How to upload a Photo/Pic to the Forum
Postby casper » Mon Dec 31, 2012 2:30 pm
Paul wrote:
casper wrote:went to use Photobucket this morning and the layout has changed :think:
I stayed with the older version as i,m used to using that one so i am going to check it out this morning to see whats changed.
Hi Casp,
Ill check the new version later as well, as recently they've added some very small minor changes
looks pretty good on first view Paul, easy to copy and paste but i need to reduce the photo size for the forum
Return to Rules, announcements & info.
