Snaps Airfix 1/24 Typhoon
Re: Snaps Airfix 1/24 Typhoon
Postby Gundog » Fri Aug 29, 2014 11:52 am
Good piece of detective work. Let's hope the repairs go well.
In the stash: Way too much
Gundog
Postby number1 » Fri Aug 29, 2014 5:50 pm
Sorry to hear of your problems snaps, hope you can continue with the build without to much more bother or giving it the :chores-chopwood:
Postby chill » Fri Aug 29, 2014 5:56 pm
Snap just posted on another thread he is binning his tiffy.
Postby number1 » Fri Aug 29, 2014 6:01 pm
Will be a shame, come on snaps Im sure you could do something with it
Postby snapdragon » Fri Aug 29, 2014 7:57 pm
If anyone wants this and can collect then they can have this. I will be getting another.
Postby Mustang » Fri Aug 29, 2014 8:15 pm
Pm sent
Postby number1 » Fri Aug 29, 2014 9:09 pm
Seems this is'nt the only tiffy that was heading for the bin, on another site I have seen that there could be fit problems if parts are painted before assembly, the thickness of the paint affecting the tight fit of the parts leading to gaps and missalignment.
Builders beware!
Postby morrigan » Sat Aug 30, 2014 9:09 pm
Looks like the tolerances on this kit are like Zoukei Mura and Wingnut Wings kits, very very fine so paint and joins is a no-no!
Postby snapdragon » Sun Aug 31, 2014 12:17 pm
That's right, also parts around the engine are also a very tight fit, not only to where they go but just getting them there too!.
My advice. Spend a week with the instructions first. Stock up on masking tape of all widths and shapes you will get though it. and once the cylinder block is on the frame work from the underside up and have the radiator pre done so you can dry fit it in place to make sure that all the connections line up as they go on!
The Tiffy will be going to a good home and hopefully Mustang will be able to rebuild and repair.... just like they did to the real thing!
I will be getting another Tiffy kit and starting again, but I need to rebuild my energy and bring the anxiety, frustration and :angry-banghead: levels down to tolerance levels.
The fault is mine, NOT the kits. I did say that this would be a learning experience and so it has been very much and I have learned a lot from it. In other words, how to build it without the problems caused by the instruction sequence.
To use some song lyrics... "To know when to walk away, and know when to run!" :laughing-rolling:
Postby steve131 » Sun Aug 31, 2014 7:00 pm
Did enjoy your diary Snapdragons, great news Typhoon being saved. Knowledge gained from this one will make next one outstanding,should be even more am goodies for your next one. K awarded for giving it to Mustang. :clap:
Postby Dazza » Sun Aug 31, 2014 7:10 pm
I have been following this build, and I am gutted for you that you had a problem, but glad to see it was saved from the bin. Will be watching to see your next Tiffy build. You deserve a K for your patience!
If at first you don't succeed, never try sky diving!!
Dazza
Return to Airfix 1/24 Typhoon
