Number1's Typhoon
Re: Number1's Typhoon
Postby number1 » Mon Oct 20, 2014 8:37 pm
Port and Starboard fuel tanks fitted, pretty straight forward.
Postby number1 » Mon Oct 20, 2014 8:42 pm
sorry, could'nt wait to try the cannons.
Postby number1 » Mon Oct 20, 2014 8:48 pm
I toned the yellow and brown paint down with a dark brown wash, I think it looks ok now. Hope B.A doesn't spot the ejector pin marks :roll:
Postby number1 » Mon Oct 20, 2014 8:57 pm
This is just dry fitted for now, just to see what it will look like, you will need to open out the holes in parts F01 and F02 for the cannons to fit through.
Thats all for now!
Postby farrabass » Wed Oct 22, 2014 2:08 pm
Coming on a treat :clap: . I found that the holes for the guns needed to be enlarged, but found that the wing parts fitted virtually perfectly. Maybe a coat of paint would have made a noticeable difference, I am painting as much as I can during a dry fit and then touching up where required when the parts are glued.
I'm off to update my build now, nearly caught you up.
All the best, Steve..
farrabass
Postby number1 » Tue Oct 28, 2014 9:31 pm
A couple more parts added, I thought it would be easier to fit out the wheel bays before adding the top of the wheel bay in place I therefore jumped from stage 130 to 175 where I continued to stage 182 before going back to add the wheel bay tops
in the photo above I have added a dark brown wash to try and bring out the detail
and finally for now the wheel bay "top" has been fitted in place.
Postby Mark » Wed Oct 29, 2014 1:44 am
There'so an I pressive amount of plumbing in the wheel wells :o Looks superb :clap:
Postby number1 » Mon Mar 09, 2015 7:18 pm
Just a small update, I have added the tail feathers, all flaps rudder etc move.
This might give you an impression of the size of the model!
Postby number1 » Mon Mar 09, 2015 7:24 pm
Just some more pics of the cockpit and various bits.
A few areas require a spot of filler.
Postby Mark » Tue Mar 10, 2015 7:32 am
Looks brilliant. The surface texture is amazing, and your cockpit is superb :clap: :clap: :clap:
Postby number1 » Tue Mar 10, 2015 3:05 pm
Thanks Mark, now the bad news, the instrument panel is glued in the wrong position, it should be a bit lower to enable the rest of the cockpit sidewalls to fit properly :angry-banghead:
Postby number1 » Mon Mar 28, 2016 7:41 pm
I've managed to finally get the Tiffy finished :dance: well apart from the rockets :( so heres a little update on the final painting
All masked up for the primer coat
Primer applied
Gunze 335 medium sea grey added to the undersides and a light scribbling of Tamiya smoke added to simulate a bit of grime
Postby number1 » Mon Mar 28, 2016 7:58 pm
Postby number1 » Mon Mar 28, 2016 8:10 pm
Next Tamiya Xf82 ocean grey was sprayed on to the topsides and masked off for the Gunze H73 dark green
Once this had dried it was out with the masking tape ready for the white Tamiya Xf2
Postby number1 » Mon Mar 28, 2016 8:16 pm
More masking needed, this time for the black stripes
Masking removed revealing the invasion stripes,
On to the decals, this one is soaking in decal sol
More later folks
Postby number1 » Mon Mar 28, 2016 8:41 pm
Here's the finished Typhoon, hope you like it!
Postby Gundog » Mon Mar 28, 2016 10:51 pm
Great job, number1, but a year between posts? :o Have a k thingy
In the stash: Way too much
Gundog
Postby Mark » Tue Mar 29, 2016 4:00 pm
Amazing job !! She looks fantastic !! Well worth a K !!
Only a year between posts ? You're a quicker builder than me :laughing-rolling:
Postby number1 » Tue Mar 29, 2016 6:35 pm
Only 1 year? Dont look at my HMS Hood diary :oops: thanks for the Ks, and for looking in :handgestures-thumbup:
Postby baby_astons » Wed Mar 30, 2016 11:02 am
oooohhhhhhhhhhhhhh I am green of envy - mine ist still boxed... brilliant job!!
Return to Airfix 1/24 Typhoon
