Paul's Airfix 1:32 VW Beetle
Thanks to Paul for kindly agreeing to run the competition again this year !
Re: Paul's Airfix 1:32 VW Beetle
Postby Paul » Fri Jan 16, 2015 2:58 pm
Mustang wrote:For the deck chairs will you be using cocktail sticks. :?:
As to the rope, how about taking one of the strands out and then re twist the others that will make it thinner.
Too late with the rope thing, as all glued in now. :oops:
with the deck chairs, I tried using match sticks last night, though not very successful :oops: :oops:
with the parasol, then cocktails sticks at the moment, so I'll see how that turns out !!!! ....... more to follow :) :)
Postby Mustang » Fri Jan 16, 2015 2:59 pm
Paul wrote:with the parasol, then cocktails sticks at the moment, so I'll see how that turns out !!!! ....... more to follow :) :)
For the parasol, just go to your local order a pint and ask for a cocktail umbrella :laughing-rolling: :laughing-rolling:
Postby Paul » Fri Jan 16, 2015 3:03 pm
Mustang wrote:For the parasol, just go to your local order a pint and ask for a cocktail umbrella :laughing-rolling: :laughing-rolling:
It was a thought, but rather too big, and also takes the fun out of things ! :) :) :)
Postby Paul » Fri Jan 16, 2015 3:41 pm
A pic of some work on the parasol with some cocktail sticks (this will be the underside).
I'm using some 151 glue, and as the paper has been varnished, the excess glue/rubber when dry will come off:
Postby Mark » Fri Jan 16, 2015 4:24 pm
How about using lengths of old guitar string to make the parasol arms ?
Postby Paul » Fri Jan 16, 2015 4:31 pm
Mark wrote:How about using lengths of old guitar string to make the parasol arms ?
Hi Mark,
A very good idea, but rather too late for me, as the sands of time are moving rather quickly here !!!!! :oops: :)
Postby Paul » Fri Jan 16, 2015 5:56 pm
Ergh Hum,
Well a few things now glued in place, though I'm still not too happy.....
I really want to do a deck chair or a lounger, and perhaps a fire in the middle. :think:
NB. I've still not worked out to do the tins as Ian mentioned, though do have some thoughts .....!!!!
Postby Mustang » Fri Jan 16, 2015 6:27 pm
:clap: :clap: :clap: speech less :clap: :clap: :clap:
Postby Paul » Fri Jan 16, 2015 6:31 pm
Mustang wrote::clap: :clap: :clap: speech less :clap: :clap: :clap:
That must be a first for you Ian !!!!! :laughing-rolling: :laughing-rolling:
In seriousness, I'm more concerned if you've been able to sort the problem with the hole on your JU :) :)
Postby Mustang » Fri Jan 16, 2015 6:36 pm
Thanks for your concern Paul.
It will be a while until we know. Still got a lot to do on the paintwork until I remove the masking tape and doors.
Postby Paul » Fri Jan 16, 2015 6:42 pm
Mustang wrote:Thanks for your concern Paul.
I really have my fingers crossed for you, though I'm sure you'll do a great job ! :D :D
Postby royjess » Fri Jan 16, 2015 10:11 pm
Paul wrote:
Loving it :clap: Looking really great. I owe you a K for this (as I must spread my Karma's :angry-banghead: )
Can't wait to see the finish diorama :D
Postby Paul » Sat Jan 17, 2015 12:06 pm
Hi Roy,
No probs, I'm just enjoying this lot !!!! :D :D
Postby Paul » Sat Jan 17, 2015 12:07 pm
Well, the bar in the backround is now done, but I've still not done the deck chair (Ergh Hum) ....
The shack is just made of card from some food packaging.
For the roof, I've used some shredded paper, sprayed it with some yellow and green, then hand painted some darker green in and a hint of brown.
The Sign was hand written, to make it look rough, using a felt pen, and then the paper "laminated" with sellotape and then attached to a cocktail stick.
Postby Paul » Sat Jan 17, 2015 12:20 pm
A bit of work in progress on a fire for the foreground (well you've got to have a BBQ on a beach!!!!).
Close up it looks like there's too much yellow and red (almost looks like a pizza gone wrong.....)!!! :oops: :laughing-rolling:
Anyway, this is just some roughly broken up match sticks on a piece of paper, all sprayed black (as a base coat) and the red and yellow hand painted in (as no Orange).
When cut out, I'll probably add some matt black to calm it down:
Postby Mark » Sat Jan 17, 2015 1:13 pm
Brilliant work Paul. Your imagination is in overdrive.
If you wanted to add some smoke to the fire, tease out some cotton wool. Works wonders.
I think you could probably add more red and yellow to the heart of the fire if you wanted to be honest. Mix the two together and you could add some orange too ;)
Postby Paul » Sat Jan 17, 2015 1:29 pm
Mark wrote:Brilliant work Paul. Your imagination is in overdrive.
Cheers Mark,
Although the fire is now in situ, that can still all be done. :D :D
A bit of more work in progress to follow.
Also, before I forget, I should have painted the inside of the hut rather than leaving in primer :angry-banghead: and also, I could have used some cut/split coffee twizzers, as planking on the outside of the hut :angry-banghead: yet again !!!! :)
Postby Paul » Sat Jan 17, 2015 1:35 pm
Well the fire is now in situ for the BBQ (NB, Mark's comments have been noted, so I might try that!):
And I'm still doing my nuts in, on how to do a Deck Chair, so I'm sure a lot more sawdust from my brains will be used up on this !!!!!
Postby casper » Sat Jan 17, 2015 2:15 pm
most excellent :handgestures-thumbupleft:
great diorama Paul, love the fire and surf boards :)
Postby Paul » Sat Jan 17, 2015 2:25 pm
casper wrote:most excellent :handgestures-thumbupleft:
BUT, still no Deck Chair though !!!!! :angry-banghead: :)
I think I need some of Morrigan's Egg Nog to think !!!!! :laughing-rolling:
Return to 2014 Xmas Competition
