Roy's Build The Millennium Falcon-Part 1 (Issues 1 to 25)
Re: Roy's Build The Millennium Falcon-Part 1 (Issues 1 to 25)
Postby royjess » Tue Apr 28, 2015 10:17 pm
That could work, my only concern is accessibility to remove and replace the removable flooring, you might need some nimble fingers or a pair of tweezers ;)
Postby R2D2 » Tue Apr 28, 2015 10:31 pm
Ive got to work that out yet! I might leave panels off revealing the secret holds! Not sure yet!
Postby royjess » Fri May 01, 2015 8:12 pm
Some more shapeways parts came today including my free replacement for the damage cockpit parts. So now I've a spare nose cone to work with.
The R2D2 that I ordered came with missing feet, so I've contacted shapeways for a replacement.
The upgrades includes a new bunk and end-walls. I've also included my original R2D2 in the photos for comparison.
ImageRBTMFP1 Fri 1 May 15 1 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 1 May 15 2 by Roy Lee, on Flickr
I now de-greased the parts and are all waiting to be painted. I finished of gluing the extra grills to the floor and then I added some plastictruct around the edge of the hole that I cut in the floor, this is to allow the new shapeways grills to sit on.
ImageRBTMFP1 Fri 1 May 15 3 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 1 May 15 4 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 1 May 15 5 by Roy Lee, on Flickr
To be continued....
Postby royjess » Thu May 07, 2015 12:19 am
Things are still a working progress for me. Today I found some time to apply some paint to my shapeways 3D parts.
Here is how my floor and fiber optic Dejarik table coming along (Fiber optics to be fitted at a later date). I've also painted the nose cone and matched the colour up nicely with the tunnel. I'm going to add detail to the nose cone at a later date.
ImageRBTMFP1 Wed 6 May 15 1 by Roy Lee, on Flickr
I've yet to paint the white strips under the floor.
ImageRBTMFP1 Wed 6 May 15 2 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 6 May 15 3 by Roy Lee, on Flickr
To be continued...
Postby baby_astons » Thu May 07, 2015 6:45 pm
cannot help myself but even if looking nicely most of the stuff could be made from plastruct for a fraction of the printing price?
Postby royjess » Fri May 08, 2015 3:36 pm
Thanks BA, but you've got to admit that the detailing on these 3D Shapes are 2nd to none.
More working progress, I've been painting more of the 3D shapes and they are coming along very well.
I've yet to add some lighting.
I've scraped some of the paint away where the white line runs at the back and side of the cockpit, the cockpit console center and the sleeping bunk lights and these will be illuminated by a LED bulb.
ImageRBTMFP1 Fri 8 May 15 1 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 8 May 15 2 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 8 May 15 3 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 8 May 15 4 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 8 May 15 5 by Roy Lee, on Flickr
ImageRBTMFP1 Fri 8 May 15 6 by Roy Lee, on Flickr
Yesterday I accidentally snapped of one of the condole levers it sprung onto the floor :angry-banghead: The broken lever was approx 2mm x 1mm very tiny :o To day I found it on the floor and glued it back on :dance:
To be continued...
Postby steve131 » Fri May 08, 2015 4:20 pm
Don't you just hate it when you snap off a bit of your model :angry-banghead: :angry-banghead: :angry-banghead: Glad you found it :dance: :dance: :dance: ,doing great job Roy :clap:
Postby R2D2 » Fri May 08, 2015 6:00 pm
I do like your add on bits but I couldn't afford them myself.
Postby royjess » Fri May 08, 2015 6:50 pm
I might have a spare nose cone and navigation seats going. At the moment I'm keeping these until the build has moved further down the line just in case I need these.
They have been painted, but the nose cone will need stripping back down to the plastic and sanding.
I'll let you know if I decided if I no longer need these at a later date and I'll give you first refusal. These will cost you nothing.
The nose cone was a replacement as the side console arrived damage and the navigation seats were what I initially purchased, and then Tony brought out the full cockpit console with more seating.
steve131 wrote:Don't you just hate it when you snap off a bit of your model :angry-banghead: :angry-banghead: :angry-banghead: Glad you found it :dance: :dance: :dance: ,doing great job Roy :clap:
Thanks Steve
Roy :D
Postby R2D2 » Fri May 08, 2015 10:26 pm
Hi Roy! I would be interested in one of your navigation seats as I need one to fit in front of the control panel in the main crew area. For some reason this kit does not have one suplied which is weired as there is definitly one shown in the films! Han Solo is sitting in it next to Obi one! :P
Postby royjess » Mon May 18, 2015 5:17 pm
Just a little update to my working progress.
Today I scrapped off some of the paint in the cockpit and navigation computer to allow some light to show through where the lights are supposed to be. I made a scraping tool from a emery-board nail file. I cut a thin strip off the emery board and glued it to the side of the emery board and it did the job.
ImageRBTMFP1 Mon 18 May 15 1 by Roy Lee, on Flickr
I've some glass paint on order to paint where I want the light to show through.
In order to fit the shapeways cockpit console and flooring, I sanded the inside of the cockpit tunnel, removing the groves and locating pins. I then fitted some plasticstruct to locate the new cockpit walls.
ImageRBTMFP1 Mon 18 May 15 2 by Roy Lee, on Flickr
ImageRBTMFP1 Mon 18 May 15 3 by Roy Lee, on Flickr
I've got two options with lighting the cockpit walls, I can either use fiber optics or simply shine a back light thought the holes which could be covered in various colours of cellophane :think:
To be continued....
Postby royjess » Tue May 19, 2015 10:20 pm
To day I've been working on the cockpit console and back wall for the illuminating.
The console had paint scraped away and replaced with glass paint (£1.99 from ebay for a set of 5 colours).
The back wall was going to be strategically covered in clear cellophane sweet wrappers. The chocolate was nice and I've now stuffed my face, but the colours wasn't that strong and it was going to be a pain to strategically glue these over individual holes.
I decided to cover the back of the wall with clear plastic used for glazing model buildings. Actually I use a lot of glazing, so I'm always saving glazing from toy and models packaging (mine came from my syma RC helicopter box). This was glued in place and then I used glass paint to paint over the individual holes.
I also covered the back of the cockpit door with black card to stop any light seeping through.
For the purpose of the photos, I held my parts up to the light as I yet to fit some LEDS and EL tape. No side walls are included in the photos today, these are yet to be added.
Due to no flash being used in order to pick up the lights, a slow shutter speed was used so please excuse the blurriness of the photos.
ImageRBTMFP1 Tue 19 May 15 1 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 2 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 3 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 4 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 5 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 6 by Roy Lee, on Flickr
ImageRBTMFP1 Tue 19 May 15 7 by Roy Lee, on Flickr
To be continued...
Postby baby_astons » Tue May 19, 2015 11:31 pm
superb job roy - btw i'm done in now, I've been resisting the dark side for 20 issues but now started buying, oh what a week nature I am...
Postby royjess » Wed May 20, 2015 11:54 am
Thank you BA, looks like the Deagostini Jedi mind trick is working on us weak minded fools :laughing-rolling:
More shapeways parts arrived today, including my replacement R2D2, computer console, Chewy crossbow and the hall arch way. One hall arch fits nicely and the other I had to use a emery board nail file to sand back to size. If any one has an image of the computer console for reference, please post me the link.
ImageRBTMFP1 Wed 20 May 15 1 by Roy Lee, on Flickr
To be continued..
Postby number1 » Wed May 20, 2015 8:58 pm
Love what you've done with the console Roy :clap: :clap: :clap:
Postby royjess » Wed May 20, 2015 11:20 pm
Thank you Number 1
I've fitted some clear plastic around the side walls and painted sections using glass paint. I glued the side wall in place. It is a very tight fit into tube, so I sanded away some of the lower cockpit tube where the cockpit console touches. I hope I've got space to fit the EL lamp.
ImageRBTMFP1 Wed 20 May 15 2 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 20 May 15 3 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 20 May 15 4 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 20 May 15 6 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 20 May 15 7 by Roy Lee, on Flickr
To be continued....
Postby royjess » Wed May 20, 2015 11:36 pm
Issue 18
More metal frame and coverings added plus two cushion archways made up.
ImageRBTMFP1 Wed 20 May 15 8 by Roy Lee, on Flickr
ImageRBTMFP1 Wed 20 May 15 9 by Roy Lee, on Flickr
To be continued....
Postby steve131 » Thu May 21, 2015 7:38 am
Will the new nose cone fit the modification, will you use it :?:
Postby tiking » Thu May 21, 2015 8:41 am
Very nicely detailed. I don't understand the lighteing system. It looks complicated just for lighting up the interior. Why so complex? I want to do something similiar but don't know how to. I thought it was just a matter of using one light source and lots of small fiber optics.
tiking
Postby Manoverboard » Thu May 21, 2015 4:41 pm
Hi Roy !
Nice work with the lighting array :clap: clever Idea using "glass Paint" and clear "plastic sheet" now that is outside the "box" have a "P" from me mate ! :laughing-rolling: ;)
Manoverboard
Return to Build diaries
