u 96
Re: u 96
Re: u 96
Postby chrispy » Fri Jan 09, 2015 9:08 pm
What is the latest issue?
chrispy
Re: u 96
Postby tigerace » Sat Jan 10, 2015 7:23 pm
latest is 19 in uk :D
tigerace
Re: u 96
Postby chrispy » Sun Jan 25, 2015 8:54 am
Done all frames and strips of wood just waiting for bits 20_23 any pics of is 20??
chrispy
Re: u 96
Postby chrispy » Mon Jan 26, 2015 4:21 pm
Also looking along the top of the model aft to forward got a bend on bits 129 hope this straightens out.
chrispy
Re: u 96
Postby chrispy » Thu Jan 29, 2015 11:51 pm
On those u96youtube it shows the guy using white glue??? To attach the plastic bits.
chrispy
Re: u 96
Postby chrispy » Sat Jan 31, 2015 6:23 pm
Can anyone answer this??
chrispy
Re: u 96
Postby baby_astons » Sat Jan 31, 2015 6:44 pm
it can be done as long as there's not too much stress on the parts - you need to be very patient though for the glue to cure...
Re: u 96
Postby chrispy » Sat Jan 31, 2015 7:16 pm
Do you know which glue his using or the right glue to use? Sorry for not been clearer in early post if it is white glue? What's the best to use?
chrispy
Re: u 96
Postby booth » Sun Feb 01, 2015 11:58 am
Take a look at these clips.
The first shows PVA (white glue) for wood to wood.
And the second shows the use of UHO for plastic to wood.
https://www.youtube.com/watch?v=w6DBSLAqKgg
https://www.youtube.com/watch?v=E5hqTtrgywg
I hope this helps
booth
Re: u 96
Postby chrispy » Sun Feb 01, 2015 1:32 pm
Tks
chrispy
Re: u 96
Postby chrispy » Tue Feb 03, 2015 1:09 pm
Sorry to be a pain just bought some uhu power glue will this be ok for plastic bits? Also got a couple of bends when looking down hull will the plastic bits straighten it out??? Tks
chrispy
Re: u 96
Postby chrispy » Wed Mar 18, 2015 3:56 pm
if any experts are at o u n d need help with u boat please??
chrispy
Re: u 96
Postby maximus2012 » Sun May 17, 2015 7:17 am
chrispy wrote:if any experts are at o u n d need help with u boat please??
For the Plastic hull parts and the planking I use medium thick Superglue, no need for pins then. Only used PVA for the MDF frames.
maximus2012
Re: u 96
Postby maximus2012 » Sun May 17, 2015 7:19 am
chrispy wrote:Sorry to be a pain just bought some uhu power glue will this be ok for plastic bits? Also got a couple of bends when looking down hull will the plastic bits straighten it out??? Tks
UHU Power glue is no good for the Plastic Hull side we got, some will be under pressure and it says in the instruction to use the thick superglue, now hurry to Poundland you get the medium thick one with accelerator for a quid and it really is good.
maximus2012
Re: u 96
Postby chrispy » Sun May 17, 2015 7:50 am
Nice to see someone finally replying to my post tks maxi :) I used that uhu glue on plastic bits worked fine, only major problem I've got is a major link on the stern???
chrispy
Re: u 96
Postby Mustang » Sun May 17, 2015 11:35 am
Looking at the photo of the hull that's a major bend. :o
Myself I would look at trying to take the plastic parts back off, and see if the hull can be re-straightened. It might not be a easy job to do.
Do you have a long straight piece of wood of metal that you can place on top of the hull to see where about the bend could be, as the photo shows it as being bent from both the bow and stern.
Re: u 96
Postby chrispy » Sun May 17, 2015 1:19 pm
It's worse about halfway down I have tried to straighten it but don't won't to make things worse. Sooooooo I'm trying to get round it??
chrispy
Re: u 96
Postby Mustang » Sun May 17, 2015 1:32 pm
Looking at the photo, I'm not sure you'll be able to without stripping some of it back in order to get to the root of the bend.
You might have to start again, if you can get the plastic parts off and the planking you might be able to heat the areas up and gently bend the parts back into line but I think that will be a tall order.
Re: u 96
Postby chrispy » Sun May 17, 2015 1:40 pm
Here's a better angle? I can with care force it straighter? http://s1231.photobucket.com/user/chris ... sort=3&o=0
chrispy
Re: u 96
Postby Mustang » Sun May 17, 2015 2:23 pm
Not really sure how to help with this.
You could look and drilling a hole in the rear area that's bent say from the last rib (38,77) to rib (32,71). And adding a small threaded rod with some washers and nut on eitherside of the ribs. But this could break the rib joins to the keel section. When you try to straighten it back up.
Another way could be to cut some small square piece of hardwood just a little larger then the gap where the bend is, place them between the ribs this could then start to push the bend back out but again the ribs might not take it.
Return to Build diaries
