John's (r2d2) Lambo build
Re: John's (r2d2) Lambo build
Postby R2D2 » Thu Feb 02, 2017 7:34 pm
Completed left hand door!
Inside of door!
Postby R2D2 » Thu Feb 02, 2017 7:45 pm
Pic showing working lock! It was quite fiddly and complicated but it works! I will show a pic of mechanism when I make the right hand door!
IMG_0905A 24bit.jpg (21.86 KiB) Viewed 4121 times
Postby R2D2 » Thu Feb 02, 2017 7:48 pm
Well thats it for now! The next pack is the last which I recon is the right hand door and any other bits required to finish this great model! I should think it will include the final assembly of the complete car and how to wire up all the connections! Can't wait!
Postby R2D2 » Thu Feb 02, 2017 11:23 pm
Just shows how much attention I was taking reading the instruction book!!! :) There was still build bits to go! Pulling the wires through from the front to rear!
Postby R2D2 » Thu Feb 02, 2017 11:25 pm
Fitted front lights including pop up lights to front wing section!
Postby R2D2 » Thu Feb 02, 2017 11:26 pm
Fitting boot to rear section! Also feeding rear light wires round the back!
Postby R2D2 » Thu Feb 02, 2017 11:33 pm
Fitted hinges to front bonnet! This was where I came across the first mistake with this kit! They had sent me two right hand hinges!!! They are plate steel and bent to the left or right so I took the chance and re bent one right hand hinge to be left! Luckily it worked although I had to paint it black where it was bent or damaged by the pliers! Saved waiting for a replacement!
Postby R2D2 » Thu Feb 02, 2017 11:35 pm
Close up of re bent hinge! You can hardly see the marks although most of it will be hidden at the bottom of the inner front section.
Postby snapdragon » Mon Feb 06, 2017 8:25 pm
I'm going to do this delivery over the next few days.
I was looking through the parts and I am thinking that there will be quite a few parts next time and lots to do with sills, putting the front bay in, connecting everything up etc. I also think that the front body section will be connected to the rest before putting it onto the lower part as I have found that is the easiest way to put them together. if you do it while the rear is on the chassis then it is much harder to get into place.
I still have not found anywhere in the instructions etc that deals with radiator hose A unless that is one of the very last pieces!
I too am waiting for the postman to bring me a nice big box next month!
Postby R2D2 » Mon Feb 06, 2017 9:38 pm
Hi there snapdragon. I can't wait for the last pack either. I think the main building of main body and front will be in this issue! Iv'e tried dry fitting the front and its really tight! There might be a suggestion in the instructions. There's also loads loads of wires to connect and I haven't got a clue how they connect up!
Postby Andrewyzfr6 » Thu Feb 09, 2017 12:01 pm
i think a lot has been left to the last delivery!
Postby R2D2 » Thu Mar 02, 2017 9:52 pm
Finally got my last pack today! here is the right hand door and parts.
Postby R2D2 » Thu Mar 02, 2017 9:54 pm
Side sills. These are metal! Rear mesh guard is plastic with metal wire.
Postby R2D2 » Thu Mar 02, 2017 9:56 pm
Wheel arch plastic guards and rear number plate mount! Number plate is actually metal!
Postby R2D2 » Thu Mar 02, 2017 9:58 pm
FItting of front spare wheel locker to front wings!
Top of front wings!
Postby R2D2 » Thu Mar 02, 2017 10:00 pm
Doors fitted to front wings! These seem quite loose but will tighten up when fitted to main body! The masking tape is just to hold the lights down during construction.
Postby R2D2 » Thu Mar 02, 2017 10:05 pm
Fitting of front wings to main body. This was very fiddly and I could have done with another pair of hands! You have to keep the doors up and open while trying to line up the pins on the front of the window frame then at the same time trying to line up the stays into the holes in the doors to both sides! Eventually did it but boy what a job!
Postby R2D2 » Thu Mar 02, 2017 10:06 pm
Top of body after fitting of front wings!
Return to Lamborghini Countach
