John's (r2d2) Lambo build
Re: John's (r2d2) Lambo build
Postby R2D2 » Thu Mar 02, 2017 10:07 pm
Wires being arranged and fed through under the frame! There are so many of them.
Postby R2D2 » Thu Mar 02, 2017 10:09 pm
Lower chassis and main body on its back lined up ready to fit together.
Postby R2D2 » Thu Mar 02, 2017 10:10 pm
Wiring connected together. There were so many and its quite a tight fit!
Postby R2D2 » Thu Mar 02, 2017 10:17 pm
Body fitted to main chassis! This was also fiddly and quite hard to fit in place! You have to make sure all the wires don't foul up on the frame. You then have to line up the steering linkage before you screw the main base down. Still all done now and the model is stunning! I only have one problem which I will have to sort out by taking off the base again! The pop up lights wont shut right down! I think I might have trapped some thing so will have to sort it out!
2
3
Postby R2D2 » Thu Mar 02, 2017 10:18 pm
4
5
Postby R2D2 » Thu Mar 02, 2017 10:19 pm
6 You can see the lights don't shut down properly. A problem that can be sorted.
Postby R2D2 » Thu Mar 02, 2017 10:21 pm
7 Lights up.
Postby R2D2 » Thu Mar 02, 2017 10:22 pm
Front spare wheel locker.
Postby R2D2 » Thu Mar 02, 2017 10:23 pm
Passenger side of car!
Top of car with door open.
Postby R2D2 » Thu Mar 02, 2017 10:25 pm
Rear engine bay open! Its really a shame that you can't see some of the detailing! But what there is is superb.
Postby R2D2 » Thu Mar 02, 2017 10:27 pm
Rear boot!
Postby Betto » Thu Mar 02, 2017 10:30 pm
Wonderful :)
Betto
Postby R2D2 » Thu Mar 02, 2017 10:34 pm
Drivers side door! tiny stalk on the steering wheel column operates the lights and horn. The accelerator pedal revs the engine and foot brake operates the rear brake lights! The ignition key actually goes in and out of the ignition barrel but is quite fiddly to insert so is best left in. All lights and sounds working fine!
Postby R2D2 » Thu Mar 02, 2017 10:35 pm
Drivers door showing a really good fit!
Postby R2D2 » Thu Mar 02, 2017 10:36 pm
Rear wheel. Nice detailing including the chrome bull in the center.
Postby R2D2 » Thu Mar 02, 2017 10:37 pm
Front wheel.
Return to Lamborghini Countach
