Deagostini E Type Jaguar
Re: Deagostini E Type Jaguar
Postby R2D2 » Wed Jan 31, 2018 9:15 pm
Parts of suspension fitted.
Postby R2D2 » Wed Jan 31, 2018 9:16 pm
Suspension completed.
Underside of suspension unit.
Postby R2D2 » Wed Jan 31, 2018 9:18 pm
Close up. Suspension works OK although there's not a lot of play. Next week is nearside suspension bits.
Postby R2D2 » Sat Feb 10, 2018 8:53 pm
Issue 47 Second suspension unit.
Postby R2D2 » Sat Feb 10, 2018 8:54 pm
Unit fitted. Did not go through building as its the same as the first only opposite side.
Postby R2D2 » Sat Feb 10, 2018 8:55 pm
Top view.
Postby R2D2 » Thu Feb 15, 2018 5:39 pm
Latest issue 48 rear anti roll bar and brackets.
Postby R2D2 » Thu Feb 15, 2018 5:40 pm
Anti roll bar fitted.
Postby R2D2 » Thu Feb 15, 2018 5:41 pm
Radius arms fitted with brackets.
Main rear drive and suspension fitted in place.
Postby R2D2 » Thu Feb 15, 2018 5:44 pm
Bracing plate fitted. Next week is issue 49 silencer.
Postby SLowner » Mon Feb 26, 2018 7:15 pm
John,
I see you did what I did at first - fitted the anti-roll bar upside down! You have to follow the instructions exactly, which is not easy since it is hard to tell the anti-roll bar orientation from the 2-D photographs. Don't worry, it is undo-able as I found - one of the joys of the De-Ag 'no glue' method.
Steve
SLowner
Postby R2D2 » Fri Mar 02, 2018 5:59 pm
This week and the next 3 issues are another wheel. As Ive already run through this I wont be entering another thread for anther three weeks!
Postby R2D2 » Tue Mar 27, 2018 1:46 pm
Anther wheel for the next 4 weeks so no build diary till then.
Postby SLowner » Thu Apr 12, 2018 9:29 pm
John,
I am having problems with the wheel retention screws. They are very tight to screw on first time but then get very loose afterwards - will probably fall off in use. In my opinion, this is a very poor retention method for such an important part of the model. Have you encountered the same difficulty?
Steve
SLowner
Postby R2D2 » Sat Apr 14, 2018 3:38 am
Not really had any problems with the wheel retaining screws! They are a tight fit but I usually slightly open the screw holes with a small drill doing it by hand! I've found I've had to do this quite a bit with the Routemaster bus part work as some of the holes have a bit of paint in them. Not a big problem just need to be careful. If your worried about the screws coming out take them out one at a time and re screw them back in using a tiny dollop of super glue! Works wonders!
Postby SLowner » Wed Apr 18, 2018 7:04 pm
John,
Thanks for the advice, but I am a little worried about fixing the wheels permanently in place - I have more than once been thankful that I can undo joints I have made! My solution was to purchase a set of 6BA metal taps to thread the holes and use 1/4 inch long set screws rather than use the diddy self-tapping screws provided which only seem to have about 2mm engagement in the axle. The taps and screws were only about £10 in total from Maidstone Engineering Supplies (amazingly quick mail order service). Given the eventual cost of this model, I am disappointed that a properly engineered wheel retention method was not used.
Don't think this method will be needed on the rear wheels, thankfully, since the screws drive into plastic, which is a lot more forgiving.
Cheers,
Steve
SLowner
Postby R2D2 » Tue Apr 24, 2018 9:41 pm
Will be restarting my build diary next week as issue 58 is the cabin floor area! This pic taken from the mag at the moment!
Postby modelcarsman » Wed Apr 25, 2018 8:16 am
There are no carpets in the kit so these might be useful...
https://www.ebay.co.uk/itm/183193267033
modelcarsman
Return to E Type Jaguar
