Galleon from DeAgostini
Postby sws35 » Tue Jan 12, 2010 4:34 pm
It will spread the instructions and build process
http://www.photoshare.ru/office/album.php?id=190100
sws35
Re: Galeon
Postby chill » Thu Jan 14, 2010 11:53 am
Ive got loads of old issues of the Lancaster I dont need.
if you want them.
Re: Galeon
Postby sws35 » Sun Jan 17, 2010 2:17 pm
Hey chill! If interested, I can start in early February to send issues of the galleon. Lancaster is very interested in me. Send your exact postal address.
sws35
Re: Galleon
Postby sws35 » Sun Jan 24, 2010 2:36 pm
I think that down a galleon to get pitching frame meaningless. Moreover, many questions about errors in the model. In particular, the layout of deck planking and location borhout (amplification plating, I do not know the correct term)
sws35
Re: Galleon
Postby sws35 » Mon Feb 15, 2010 8:57 am
Issue 4 came out, but until something impossible to stick together. Waiting to issue 10
sws35
Re: Galleon
Postby sws35 » Tue Feb 23, 2010 11:53 am
The first 6 frames pasted into place and put the front part of the lower deck. Except for the frame number 4, all in order.
sws35
Re: Galleon
Postby Mark » Tue Feb 23, 2010 1:07 pm
That's looking good. This early stage always seems to take an age to build anything significant !
I like your jig that is keeping the keel straight.
Re: Galleon
Postby sws35 » Thu Mar 04, 2010 11:29 am
Issue 7, yet assembled without glue.
Anchors will use a set, and anchor rods cause a desire to replace them.
sws35
Re: Galleon
Postby Mark » Thu Mar 04, 2010 11:35 am
That's coming on nicely. I think I would probably wait until the ply deck is complete before adding the planking, but each to their own.
Thanks for showing us how this is coming on Sergie
Re: Galleon
Postby sws35 » Thu Mar 04, 2010 5:16 pm
Hi Mark! Thank you for your approval.
The lower deck will not be seen, I'll do starboard closed. This is purely for training and testing method of installation of deck planking.
sws35
Re: Galleon
Postby sws35 » Sun Mar 14, 2010 11:03 pm
Receiving the eighth issue, and trying to establish the place of the middle part of the lower deck, I was surprised to find that most of the flaws disappeared by itself. Apparently the error compensated.
All three of the bottom deck formed normally, stuck to all the beams.
Several surprise rise of 4 degrees of 8 frame to the 9th, but looking at the picture from a friend, came to the conclusion that it should be. With sheer everything was in order.
Proceeded to erect decking and everything else associated with him.
Hope it will be possible to sew at least part of the nose did not come true, he had to make shorter boards, and I just took a long board in the quadrat 3. 'll Have to wait for 15 issues.
I tried to install the master rail
Conclusion - easy problems will have to take virgin rail.
With respect to the front edge of the deck at the 1st frame, there's an ambush.
Much thou hast gathered - will fail, not enough - the hill in this place. Here's a practical question for 3D modeling. We'll have to put MAX, PC, where he was standing in the condition of the dead.
'll Have to postpone the construction before the issuance of 15.
sws35
Re: Galleon
Postby sws35 » Tue Apr 13, 2010 5:42 pm
Prior to completion of a set of housing remaining weeks. Will finish lower deck
sws35
Re: Galleon
Postby Mark » Wed Apr 14, 2010 10:55 am
She is starting to look very impressive Sergie. I see you are using black cotton as the caulking between the planks. That is the same method I like to use. It is very effective.
Re: Galleon
Postby sws35 » Mon Apr 26, 2010 8:59 pm
Released 14 issue galleon.
I can do the lower deck
The deck is ready, now I have measured the plan for further construction
sws35
Re: Galleon
Postby sws35 » Wed Apr 28, 2010 8:09 pm
Received 15 release. Install the upper deck and Quaterdeck without glue. Details in tandem to good.
Hi Mark! Duplicated several posts here on the "build the Bismark".
sws35
Re: Galleon
Postby GrantJ » Thu Apr 29, 2010 6:15 am
Well done sws!
I really like your deck planking with the black cotton between the planks - had heard about this method but this is the first time I have seen it.
Have a K for that and for inspiring me to use this method on my Victory (when I get to that stage)
Building:
HMS Victory
Akagi
Bounty (on hold)
Built:
GrantJ
Re: Galleon
Postby sws35 » Thu Apr 29, 2010 10:42 pm
GrantJ wrote:Well done sws!
Thank you! And what is your Victory would be the size of a deck plank flooring? At Galleon, I used cotton thread number 10. If the flooring planks is less is better to use synthetic thread, or paste in between the slats glassine strips. But I try to use cotton. To the thread is not mahram, I handle it diluted PVA.
sws35
Re: Galleon
Postby GrantJ » Fri Apr 30, 2010 6:43 am
At this point i do not know the size of the planking on the Victory as it is also partworks like your Galleon.
We will have to wait and see when those issues are released :)
Building:
HMS Victory
Akagi
Bounty (on hold)
Built:
GrantJ
Re: Galleon
Postby sws35 » Sat May 01, 2010 11:14 am
We are going to release a "Victory".
And they promised:
But there is no information when.
The store set from Amati is 50000 rubles, about 1000 pounds. Quite expensive. Victory 1:100 scale, given that the decking boards at this time were shorter than in the days of galleons, I hesitate to say anything about it. This Belgian site about the construction of Victory, though it is Russian.
http://chez-xandra.be/publ/12
sws35
Re: Galleon
Postby Mark » Sun May 02, 2010 11:02 pm
That looks like the Del Prado Victory. I don't know if they've re-worked the it for the Russian market, but some people in the UK didn't think it was very good quality.
The train looks interesting.
Return to Other ships
