Galleon from DeAgostini
Re: Galleon from DeAgostini
Postby GrantJ » Sun Jul 18, 2010 5:13 pm
Great work by you and your helpers on the planking - it looks really good :)
Building:
HMS Victory
Akagi
Bounty (on hold)
Built:
GrantJ
Postby sws35 » Tue Jul 27, 2010 9:25 pm
Thank you for the kind words!
I started to lay rails rough planking. Just got out flaws in the model in the bow. In the first frame of the kink is formed. I shall have to work with putty and a file.
sws35
Postby sws35 » Wed Aug 04, 2010 9:26 am
Established deatl with porthole. Strongly thinking. Sew up the second board, or do the instructions with an open rim
sws35
Postby chill » Wed Aug 04, 2010 2:12 pm
COENIE wrote:By the look of them, I'll say KEEP them in the woods. :shock:
I want to say, rather get yourself a couple of dancing girls, but on second thought, they might also delay your build. :D
Your build looks good so far, keep it going.
Sound advice!!!
Postby GrantJ » Wed Aug 04, 2010 5:29 pm
That is looking really nice now Sergei :D
i
To see it standing next to the Bismarck it looks to be a large model!
Building:
HMS Victory
Akagi
Bounty (on hold)
Built:
GrantJ
Postby snapdragon » Sat Oct 16, 2010 7:41 pm
I think Amati have totally reworked the Titanic kit and it now features etched brass detail instead of those really naff coloured printed card stuff. I could be wrong though maybe someone else could confirm that?????
Everything looks great Sergi
Postby COENIE » Sun Oct 17, 2010 10:10 am
Hi Sergei, how about an update mate. I really hope you didn't take me serious with the dancing girls suggestion. :D
I started here ... viewtopic.php?f=57&t=228#p1377
and is now finish with ... viewtopic.php?f=48&t=339
COENIE
Postby sws35 » Tue Oct 19, 2010 6:56 pm
Hi friends! I was absent for some time. I was invited to inspect a replica built aircraft of World War I.
In Russia, there was a new partwork DEA, as I open an appropriate topic.
In the near future will put the continuation of construction galleon
sws35
Postby mike » Tue Oct 19, 2010 8:54 pm
Hi Sergie
Pleased to see you back mate, is that your goodself stood by the aircraft, do you know what type it is.
Looking forwards to more build on your galleon :D :D
mike
mike
Postby Mark » Tue Oct 19, 2010 9:08 pm
Nice photos Sergie, that looks like a beautiful aircraft.
Glad to see you back, and I'm looking forward to seeing more of your galleon :)
Postby sws35 » Wed Oct 20, 2010 6:20 am
Hi! Gradually moved from the manufacture of rough skin. Really want to understand the principles of laying planks.
The instructions given to the method with a variety of triangular inserts. I do not like it. I can experiment on the rough upholstery that would be prepared to finish plating.
sws35
Postby Eric » Wed Oct 20, 2010 7:07 am
The triangular inserts are called 'stealers' and are normal in such builds, a bit of practice and you'll get the hang of it!
I had to make a lot of stealers when I did my HMS President build (unfinished) and with time got quite good at them.
Postby sws35 » Wed Oct 20, 2010 9:02 am
Thank you for the tip, Eric!
We are called (literally) "poteryaynye" belt lining the vessel. (In any dictionary could not find the translation, Google, the same is not right). The closest value - to lose. Normal zone of the shell plating to be from the stem to sternpost, and those where some go to zero.
Something like this:
But how it could look like on real ships?
sws35
Postby Mark » Wed Oct 20, 2010 10:54 am
The word in English is Dropper, which is when one plank stops before the bow/stern, which I can see in your photo.
We also use the word Stealer, which is when you put an extra short plank in to fill a gap, usually near the stern.
Postby sws35 » Fri Oct 22, 2010 5:27 am
Thanks Mark! I'm starting to understand a little issue with the skin. Released 40 issue.
Galleon now looks like this:
sws35
Postby sws35 » Fri Oct 29, 2010 1:10 pm
41 issue
Began to form the bow of the ship. A little more and start finishing plating.
sws35
Postby COENIE » Fri Oct 29, 2010 3:00 pm
Nice work, Sergei. Keep it up mate.
It appears that the Galleon is about half the size of the Bismarck, so maybe you don't have so many arguments on where to display it eventually. :)
COENIE
Postby sws35 » Sun Nov 14, 2010 5:34 pm
Proceeded to install finishing plating
sws35
Postby mike » Mon Nov 15, 2010 9:18 pm
The Galleon's looking good Sergie
mike
Postby sws35 » Fri Nov 19, 2010 11:23 pm
Thanks Mike! But I already knew that finishing sheathing will be a big problem. Artezaniya Latina...
sws35
Return to Other ships
