MY BUS TEST
Hachette's iconic red London bus
MY BUS TEST
MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:40 pm
Hi all! Bought the first issue of the Hachette build the Routemaster bus just to see the quality! If I'm happy with it I might Buy the whole thing at my local newsagents! I drove these in the 70s for East Kent and actually passed my test in a Routemaster. Regarding the bonnet! There was a gap on the hood as in the summer the engines used to overheat so the maintanance crews adjusted the catches to make a gap to help cool the engines!
Re: MY BUS TEST
Rear of first issue!
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:43 pm
Parts taken out of packets. Quality is pretty good as far as I can see. We will have to see how it fits together to find out if the fit and quality continue!
Re: MY BUS TEST
Number plate fitted (easy).
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:44 pm
Grill fitted.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:45 pm
Rear of grill. Plastic washers hold it in place.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:48 pm
Hinges fitted to side panel. I suggest reaming out the holes as the screws are a tight fit because of paint in them and could split. That's what I did and had no problems.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:49 pm
Outside of panel with hinges.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:50 pm
Panel fitted to bonnet!
Re: MY BUS TEST
Side of bonnet showing inspection panel closed.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:51 pm
Panel opened.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:52 pm
Inner frame fitted to main bonnet.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:53 pm
Main bonnet.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 3:59 pm
Main bonnet resting on front grill. So far the quality in my opinion is pretty good! Looking at the bonnet and grill dimentions this is going to be a really big model even in 1/12the scale! I know the screws showing on the finished model could be a bit of an issue with some people but if I do decide to get this model I'm thinking of painting the screw heads red where exposed! This would lesson the problem. I might even do a major mod and paint the whole bus in East Kent colours (Cream and maroon).
Re: MY BUS TEST
Postby Cyborg8888 » Sat Jan 27, 2018 4:44 pm
Looking forward to seeing your mods on this fantastic bus.
I was thinking of using micro rivets instead of the screws but will have to see exactly how they are putting this together. Just a thought.
Cyborg8888
Re: MY BUS TEST
Postby steve131 » Sat Jan 27, 2018 4:46 pm
Looks a nice model ,would like to see your talent put too work on it. :dance: :think:
Re: MY BUS TEST
Postby wingnut2 » Sat Jan 27, 2018 5:19 pm
Hi John, sorry to say I couldn't see your pics ? or is that just me ?
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 5:23 pm
The pics are there! You may need to update your graphic system!
Re: MY BUS TEST
Postby steve131 » Sat Jan 27, 2018 5:24 pm
I can see them.
Re: MY BUS TEST
Postby R2D2 » Sat Jan 27, 2018 5:26 pm
Hi cyborg8888! I to thought of rivets but they would have to be pretty small and the work involved would be to much!
Return to Routemaster Bus
