MY BUS TEST
Hachette's iconic red London bus
Re: MY BUS TEST
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:29 am
Issue 55 switches, wire, screws' and inner panels.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:30 am
Wires fixed in place.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:31 am
Inner panels fitted.
Re: MY BUS TEST
Inner rear wall fitted in place to rear of bus.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:32 am
Issue 56 front inner roof section.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:33 am
Parts fitted including hand rails.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:34 am
Front roof section temp fitted. Looking the part.
Re: MY BUS TEST
Postby R2D2 » Sat Mar 23, 2019 1:35 am
Temp fitted onto bus chassis. Looking very busy.
Re: MY BUS TEST
Postby corelki2005 » Sat Mar 23, 2019 8:38 am
Me thinks that you have got that in the wrong position as that is the rear section of the lower deck ceiling
Nick
corelki2005
Re: MY BUS TEST
Postby number1 » Sat Mar 23, 2019 7:03 pm
I've just seen one of these part built at the Yeovil model show, must say it looks very impressive now I've seen it in the "flesh". keep up the good work your doing.
Re: MY BUS TEST
Postby R2D2 » Wed Mar 27, 2019 3:32 pm
Hm you could be right! I didn't look to see where the roof goes. OOps!
Re: MY BUS TEST
Postby steve131 » Sun Mar 31, 2019 8:49 pm
Lovely model , do you get a cover for the back of the seats to cover the screws ?
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:18 am
Issue 57 Main inner roof section.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:19 am
Main roof fitted out and attached to rear inner roof section.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:20 am
Completed roof temp fitted to bus. Looking huge!
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:22 am
Issue 58 Rear main step and LED lights plus battery box.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:23 am
Switch fitted to rear step unit. The rear step is metal and pretty heavy.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:24 am
LED lights fitted to roof.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:25 am
Issue 59 rear luggage section parts and electronic board.
Re: MY BUS TEST
Postby R2D2 » Fri Apr 05, 2019 1:26 am
Parts built up but only temp fitted to rear step area. Will look great when fitted to rear of chassis.
Return to Routemaster Bus
