HKM B-17F 'Memphis Belle' Completed
The gloves are off!
Re: Morris' HKM B-17F 'Memphis Belle'
Postby steve131 » Sun Feb 03, 2019 7:40 pm
Lovely work good idea with the non slip floor 8-)
Postby Morris » Sat Feb 09, 2019 1:04 pm
More done on the cockpit today - went with the insulated quilted lining on the walls - James, the first diagram below shows black out curtains in a '17 - didn't know they had them.... :?
1/48 Tamiya Mig 15
Postby snapdragon » Sat Feb 09, 2019 2:31 pm
I didn't know about the blackout curtains either.
You might want to check on the Memphis belle restoration photos and see if they are put in. The yanks bombed by daylight in the European theatre, so I don't see the use for them and they might have been removed. Also check other interior photos on B-17's They might have only been put in for transportation flights from the factory.
That insulation quilting looks good. What did you use? Also, the Eduard stuff certainly adds to the detail!
I have had chance to go through the Lancaster box and there were no spares for the B-17. I'll try Neil again. Sorry for this. If needs must you can have the sprue from my kit.
Postby Morris » Sat Feb 09, 2019 3:09 pm
snapdragon wrote:I didn't know about the blackout curtains either.
I think they removed the black out curtains like you say due to the daylight campaign - I used wedding invitation sample card stock that I painted and washed - :D
No worries on the spare sprue /parts - I will try :D
1/48 Tamiya Mig 15
Postby snapdragon » Sat Feb 09, 2019 5:14 pm
Had a word with HK and told they will be posted on the 14th when china goes back to work!
Postby Morris » Sat Feb 09, 2019 5:33 pm
Thanks for help James
1/48 Tamiya Mig 15
Postby Morris » Sat Feb 16, 2019 5:20 pm
A bit more done on the port side and I'm near the end of the 2nd page of instructions - Still struggling for an effect for the green straps on the oxy tanks,...PE is too small for me....trying tape...
Back bulk head to start tomorrow...
1/48 Tamiya Mig 15
Postby royjess » Sat Feb 16, 2019 6:12 pm
Your doing a stunning job there Morris :o :clap:
Postby number1 » Sat Feb 16, 2019 7:54 pm
Agree with Roy, stunning work :clap: :clap: :clap:
Postby steve131 » Sat Feb 16, 2019 8:25 pm
number1 wrote:Agree with Roy, stunning work :clap: :clap: :clap:
Agreed 8-)
Postby snapdragon » Sun Feb 17, 2019 11:11 am
Outstanding work, Morris. I hope my Lanc when I start comes out like this!
Postby Morris » Sun Feb 17, 2019 1:30 pm
Thanks all for looking in - Your Lanc will be awesome based on past observations of your work -, James - awaiting your start also :) ......Finished the back bulkhead of the pilot's cabin (behind the top turret position) - That's the last of the 'quilted' insulation in this area - no more to so till I get to the radio op compartment....Bomb bay next and starts next week - It will take a few weekends I think...
1/48 Tamiya Mig 15
Postby Morris » Sat Feb 23, 2019 2:17 pm
moving on to the bomb bay - Again using the real Belle in her refurbished colours at the USAF museum.....
I didn't want to cut the port bomb rack form the kit wall section as it had locater pins on the back sid e- figured I'd need those when closing the fuselage....So I kinda cut and married the kit and Eduard pieces. Followed by struts and bits and pieces...
Then painted it the colours form the USAF museum example. Will start the stbd wall tomorrow - Not sure if I'm putting in bombs as yet -
1/48 Tamiya Mig 15
Postby Mark » Sat Feb 23, 2019 6:01 pm
Great detail on the bulkheads. It adds a lot to the model.
Postby Morris » Sun Feb 24, 2019 12:46 pm
Continue with the centre trestle and bomb racks (the centre bomb racks made up my mind about putting the bombs in, I will have to as there is only 3 release mechanisms moulded in the rack frames....I got ahead of myself on the stbd bay wall and mounted the little j-boxes on the wrong side - I'm afraid I will wreck hem to pull and move them.... :( - I still haven't figured out if I need to put non-slip on the trestle walkway.....Surifng the net at present on that one....
1/48 Tamiya Mig 15
Postby snapdragon » Sun Feb 24, 2019 12:53 pm
Going well, Morris. The Eduard stuff certainly adds to the areas
Postby Morris » Fri Mar 08, 2019 8:26 pm
After trimming back some of the quilting on the back cockpit wall - Started the front side of the bomb bay again....Added some non-skid (sand paper) to the bomb bay bridge and the front hand ropes....
1/48 Tamiya Mig 15
Postby royjess » Sat Mar 09, 2019 9:51 am
Incredible work as usual Morris :clap:
Postby number1 » Sat Mar 09, 2019 12:42 pm
Agree with Roy, incredible :clap: :clap: :clap:
Postby Morris » Sat Mar 09, 2019 8:49 pm
Back bulkhead - bomb bay -
Then removed details on radio compartment side in prep for quilted insulation again...
Will start on some bombs next....
1/48 Tamiya Mig 15
