replacement pt AS-3
How to deal with the ally skinning
replacement pt AS-3
replacement pt AS-3
Postby davebird2003 » Thu Sep 01, 2011 3:06 pm
As i was having problems with fitting pt AS-3 which was part of the part 62 build,i was told on this forum that some customers had received the wrong size part and that a replacement part was in issue 69,so far so good!
I opened issue 69 and there was a note apologising for the mistake along with replacement pt AS-3 but on examining both parts i have found that the old part measures 105mm x 60mm and the replacement part measures 105mm x 65mm so although i have a replacement part it is no good because i still haven't got the 1mm overhang i need to fit the part on to the frame as per the instructions in issue 62!
Can anyone tell me how to get around this problem and whether the 1mm overhang is really essential to the build???
davebird2003
Re: replacement pt AS-3
Postby Mark » Thu Sep 01, 2011 11:31 pm
Sorry, I haven't added any of the skin yet.
Postby GOONBIRD » Sun Feb 26, 2012 7:02 pm
Hi !
An excellent source of thin alluminium and steel, are drinks cans.
So use this to make your own skins!
Problem is, the contents have to be consumed first! ;)
GOONBIRD
Private
Private
Postby Julian » Sun Feb 26, 2012 7:14 pm
Fosters.........
Timmy Mallet
Postby Mark » Mon Feb 27, 2012 2:21 am
John Smiths......... Top bombing, so it's ideal for the Lanc :laughing-rolling:
Return to Skinning
