Which material will the skinning be ?
How to deal with the ally skinning
Postby 9JL » Fri Oct 16, 2009 7:04 pm
Self adhesive metal skinning ? peel the back off and stick down,I wonder ? we will have to wait and see that exciting stage of the construction.
9JL
Re: Which material will the skinning be ?
Postby chill » Sat Oct 17, 2009 4:34 pm
Looks like ali that is glued on.
Postby 9JL » Sat Oct 17, 2009 7:07 pm
Something comes to mind straight away to do this job,Scotch 3M adhesive spray,it has a working time of aprox 8 minutes to juggle things around,could be useful for this mammoth task ahead.
9JL
Postby Mark » Sun Oct 18, 2009 9:50 pm
...or slow setting Araldite.... for those who like plently of time to get things in the right position ;)
Postby Russ » Sun Oct 18, 2009 9:57 pm
What about Two part epoxy resin a small amount
LOOK LOOK .... OVER THERE .... SORRY WHAT WERE WE LOOKING AT AGAIN ???
Russ
Postby chill » Mon Oct 19, 2009 7:50 am
No More Nails.
Gets his coat.
Postby 9JL » Mon Oct 19, 2009 9:34 pm
Mark wrote:...or slow setting Araldite.... for those who like plently of time to get things in the right position ;)
Yes I still like that older version of araldite,most modern epoxies set far too quickly,I tried my rivetting tool out today on some litho plate,it works well,there is a lot of rivets on a Lanc !
9JL
Return to Skinning
