Issue 4
Want to talk about a particular issue ? Please put the issue number in the post title.
Issue 4
Issue 4
Postby drh1963 » Sun Jan 24, 2010 10:17 pm
A word to the wise. Make sure that when you are assembling the cabin formers, you take note of the orientation of part nos 53 and 51. Both these parts have a small inward facing ledge. This ledge should be on the right as you look down the cabin towards part 55.
If you look at pictures 27 and 35 in issue no 5 you will notice that the wedge on part no 53 is on the left. This is wrong.
On another note, I use a glue called Aliphatic Wood Glue when joining wood components together. It has an excellent quick grab, has a rapid cure and is easily sandable. It is non toxic and non fuming. A really good glue perfect for this project.
Most good model shops should stock it. A 500g bottle will last you forever!!
Make sure to, that you use a gel form of super glue as this doesn't run all over the place when you apply it.
drh1963
Cadet
Return to Discussions on specific issues
