LOOK OUT FOR DARTH VADER
Re: LOOK OUT FOR DARTH VADER
Postby R2D2 » Tue Jul 05, 2016 10:57 pm
The only difference with my design is that Iv'e managed to fit the Ben Ten voice changer inside the Hasbro chest piece! Here is the switch arangment!
Postby R2D2 » Tue Jul 05, 2016 11:01 pm
here is the inside arangment! The LED's run off 3 volts and the Voice changer on 4.5 volts! At the moment I'm not sure how long the batteries will last but if its less than an hour I might have to produce another form of power source!
Postby R2D2 » Tue Jul 05, 2016 11:02 pm
Mike in the mask was changed for the Ben Ten one because its a better quality.
Postby R2D2 » Tue Jul 05, 2016 11:04 pm
Close up of Ben Ten voice changer. This took a bit of chopping about and modifying.
Postby R2D2 » Tue Jul 05, 2016 11:11 pm
Completed units fitted to manaquin with Chest piece left open!
Postby R2D2 » Tue Jul 05, 2016 11:20 pm
How units will look after fitting! The i station is well hidden but the sound comes out really well! Although the Ben Ten voice changer is not 100% Darth Vader its pretty close and when amplified sounds menacing with a slight echo! The amp is 6 watts and although fairly close to the mike gets only a little feed back if the volume is up to its max! Mind you if its to high it sounds distorted anyway. Because Iv'e fitted the voice changer to be able to change you can make Darth sound like Micky Mouse or even a Dalek which is really funny! The flashing LED's also work well and look pretty good especially in low light!
Postby Mark » Wed Jul 06, 2016 12:59 am
Nice job. Good solution for the sound.
Have a K :clap:
Postby casper » Wed Jul 06, 2016 2:33 pm
good job R2 :clap: :clap: :)
looks great
Postby R2D2 » Wed Jul 06, 2016 6:25 pm
Thanks for your comments! I will be using the costume at the August bank holiday and at the carnival in Herne Bay this year! I hope to get a good reaction from the crowd. I'll be using it mainly to promote the local Toy collectors shop which is RAM Collectibletoys.co.uk Mind you! I hope its not to hot because it gets really humid and hot in the costume!
