Unimat lathe
Unimat lathe
Unimat lathe
Postby R2D2 » Sat Feb 11, 2017 7:31 pm
Bought this Unimat lathe and other bits at a boot fare for a silly price of £30! A great bargain. The motor runs from 240 volts main power. Its quite powerful. There is the Unimat motor housing but no motor. Needs a good clean but it all works! Will be great for machining parts for my models. Ive seen these going for around £200 complete so a great bargain with a much bigger motor!
Re: Unimat lathe
Postby R2D2 » Sat Feb 11, 2017 7:32 pm
Close up of machine bed! All needs a clean but all working.
Re: Unimat lathe
Postby R2D2 » Sat Feb 11, 2017 7:33 pm
Tin full of spare collets and other bits!
Re: Unimat lathe
Postby R2D2 » Sat Feb 11, 2017 7:36 pm
More accesories and extending bed! This will come in useful to make bits for my cars.
Re: Unimat lathe
Postby number1 » Sat Feb 11, 2017 8:46 pm
Nice find, worth every penny I think :clap:
Re: Unimat lathe
Postby morrigan » Sun Feb 12, 2017 2:37 am
That should keep yopu busy for a while. A good find indeed
Re: Unimat lathe
Postby Mark » Sun Feb 12, 2017 5:45 am
Needs a bit of a clean, but certainly a cracking' bargain !!
Re: Unimat lathe
Postby wingnut » Sun Feb 12, 2017 6:02 pm
Nice find :mrgreen: a bit of "elbow grease" and your all set up.
Re: Unimat lathe
Postby casper » Sun Feb 12, 2017 6:59 pm
What a bargain :o nice find R2
extra tools available and plenty of parts online
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:02 pm
Cleaned up Unimat fitted to a new board. I stripped each seperate unit down and cleaned with a a wire brush on a Dremel drill.
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:03 pm
Chuck and tool post stripped and cleaned plus oiled. All looking good.
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:04 pm
Center post cleaned up and oiled.
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:06 pm
Extra bits all cleaned! These parts are used to make a pillar drill or milling machine!
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:08 pm
Left of lathe! The drive belt is ok but I will buy a proper Unimat motor at some time so I can use the milling machine option.
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:11 pm
The mains motor is a bit dangerous with the electrics being exposed but I'm going box the whole thing in to make it safer!
Re: Unimat lathe
Postby R2D2 » Mon Feb 13, 2017 10:13 pm
Close up of nice clean chuck. I was suprised to find this is metal with plastic jaws. It works quite well.
