Mosquito 1/48 'The Wooden Wonder'
Re: Mosquito 1/48 'The Wooden Wonder'
Postby Mustang » Mon Sep 14, 2015 6:45 pm
morrigan wrote:Now that's a Wooden Wonder! :clap: :clap:
Thanks Morrigan :) , nice to see you on here as I haven't seen you around for a while.
Postby chill » Mon Sep 14, 2015 6:49 pm
Looks great are you getting the tamiya mossie?
Postby Mustang » Mon Sep 14, 2015 7:00 pm
Hi chill.
I would like to, I'm hoping that a friend will won't one as he's a big Mossie fan but can't build a kit. So I've offered to build one for him just asked to cover the cost of glue and paints and a little for my time as I think I would like the build.
Oh unless you want to send me one :laughing-rolling: :laughing-rolling:
Postby chill » Mon Sep 14, 2015 9:32 pm
Was about to ask the same to build mine :)
Postby Mustang » Mon Sep 14, 2015 10:01 pm
chill wrote:Was about to ask the same to build mine :)
The door is always open to a challenge ;)
Postby Mustang » Sat Dec 02, 2017 8:02 pm
number1 wrote:Should keep you busy for a couple of days :laughing-rolling:
:think: :think: this is still in the build process 3yrs since I started this
:oops: got side tracked plus other things took over :oops:
updating the photos....
Postby Morris » Sun Dec 03, 2017 4:09 pm
I was just reading this one, ....jig cutting and applying those decals in conjunction with the metal foil is making for an awesome look! Would like to see more of this build when you get a chance :)
Hachette Spitfire Mk1a partworks up to including issues 43-46
DeAgonstini Ford GT40 part work pack 8
Agora Models 427 AC Cobra pack 2
Posting some Lost in Space threads..
Postby snapdragon » Sun Dec 03, 2017 6:43 pm
Looks great Mustang!
Just one thing that not many people know.
The Mosquito was not only a wooden built aircraft, but over the top of that was a covering of fabric and then doped. It stiffened everything up. The entire outer skin of the aircraft was covered in this fashion. Once dry it was then painted.
Postby Mustang » Sat Apr 20, 2019 6:13 pm
This has been sitting in a display case waiting to be finished, so today I finally got it back on the bench and just sat there trying to work out where I was with the build.
I'll hopefully get on with this one now. :oops: :oops: with the Harrier finished and the Testarossa nearly there it's time to get this one finished, unless something else pops up :roll:
Postby Mustang » Tue Apr 23, 2019 9:41 pm
Just a couple of small bits, while I still work on the wing decals.
It won't be staying here as I'll have it sitting on the wing awaiting to be fitted or just been removed.
Postby Mustang » Tue Apr 23, 2019 9:43 pm
Undercarriage all done nothing exciting, kit parts with weighted wheels.
Postby casper » Wed Apr 24, 2019 10:40 am
Good to see the "wooden Wonder" back on your bench matey, looking forward to your updates :D
Postby steve131 » Wed Apr 24, 2019 8:51 pm
casper wrote:Good to see the "wooden Wonder" back on your bench matey, looking forward to your updates :D
Agree with Casp
Postby Mustang » Wed May 01, 2019 10:03 pm
cheers guys.
Postby Mustang » Wed May 01, 2019 10:05 pm
So I've done the engines.
Postby Mustang » Wed May 01, 2019 10:06 pm
Postby Mustang » Wed May 01, 2019 10:07 pm
Support frames.
Postby Mustang » Wed May 01, 2019 10:10 pm
Finally finished all the decals today, these decals are great and I would use them again but the foil not so much.
All I have to do with the wings is to add a couple of coats of the oil to seal them, so thats tomorrow. But I'll have to get on with something else while that all drys.
Postby Mustang » Wed May 01, 2019 10:16 pm
Had an issue once the wings where glued on they where out by 1mm from wing tip to wing tip, so to sort this out I could either sand down the port wheel or add to the starboard one.
So I placed a piece of plasticard under the wheel which made the aircraft sit better.
All I had to do then was to reshape the bottom of the tyre, and sand the bottom just a little bit.
Now it sits better.
Postby Mustang » Wed May 01, 2019 10:19 pm
So as I said earlier this will be back on the bench once the oil coat has dried, that could take unto 2 months :(
