Airfix 1/24 Harrier
Re: Airfix 1/24 Harrier
Postby Mustang » Sun Dec 03, 2017 7:37 pm
I also replaced the centre support in the engine bay as the plastic piece I added didn't work right, so I used thin metal.
Postby Mustang » Sun Dec 03, 2017 7:44 pm
The instruction have you building the kit with the rear horizontal stabiliser's in place before you join the fuselage together, I didn't like that way as I wanted the paint them separately.
So I drilled a whole though the fuselage.
Added a piece of brass pole.
This would allow for these to fit inside.
Just placed in place loosely.
Postby Mustang » Sun Dec 03, 2017 7:46 pm
I also added some more detail to the out riggers
Postby Mustang » Sun Dec 03, 2017 7:47 pm
I also added supports to the heat shields.
Postby Mustang » Sun Dec 03, 2017 7:48 pm
Rear main wheel, again very basic so I added some wire.
Postby Mustang » Sun Dec 03, 2017 7:54 pm
Next was the pilot, I wasn't going to have him sitting in the cockpit. I wanted him standing outside the aircraft like he was waiting to get going.
So the kit gives you this.
First job was to cut him up.
Then to try and rebuild him
So using plasticard to hold him in place.
Postby Mustang » Sun Dec 03, 2017 7:55 pm
Then the filler.
and sanding
Postby number1 » Sun Dec 03, 2017 8:56 pm
Fantastic amount of scratch building, must be one of the best detailed model Harriers out there.
Postby Mustang » Tue Dec 05, 2017 10:49 pm
Cheers N1.
Canopy added this needed some filler around the bottom
Postby Mustang » Tue Dec 05, 2017 11:00 pm
Next I worked on the pylon release mechanism
This is what you get to make one release unit and theres two per pylon.
I cut a slot in the rear section so the whole unit could fit straight in.
At the front I cut the brass bit in half, so I could leave the plug to support the armament unit.
Then cut out a small square to fit the unit into.
In the end I ended up with this.
Dry run to see how they looked.
Postby Mustang » Tue Dec 05, 2017 11:04 pm
A coat of primer and filling of some of the areas.
Postby Mustang » Tue Dec 05, 2017 11:10 pm
Next was the cluster bomb that sits under the centre of the aircraft.
First part was to fit the brass top section, I also added two brass pins to help glue the bomb to the pylon.
Next was the support parts to make it look like there the true parts holding the two pieces together.
Final part was to add brass rods to the small holes.
Postby Mustang » Tue Dec 05, 2017 11:16 pm
Next step on the pilot was to change the guys head. So I brought some figures to use as ground crew, and used one of the heads for the pilot.
I also managed to remove the old head from the helmet.
Made a drink bottle.
Some of the team.
Postby Mustang » Tue Dec 05, 2017 11:19 pm
Coat of grey.
Then once dry I freehanded the green came patten.
Postby Mustang » Tue Dec 05, 2017 11:25 pm
The kit doesn't come with any detail for the canopy DET cord.
The DET cord was designed to crack the canopy before the seat and pilot hit it.
So I managed to find a guy that made this for me.
Once fitted it look perfect.
Postby Mustang » Tue Dec 05, 2017 11:31 pm
The base was just made up from scrape bits I had in the garage.
First need to work out the size of the base.
Then added some edging to the base.
I used some grass sheets.
Then added the flock you use on railways.
Secured this with a mix of wood glue and water sprayed on.
Then just kept adding different colours to get the look I wanted.
Postby Mustang » Tue Dec 05, 2017 11:36 pm
Then I added the PSP planking.
I used a mix of acrylic and oil paint on these.
Postby Mustang » Tue Dec 05, 2017 11:41 pm
All the extras
You'll notice on the sign a slight colour distortion in the corner, This happened when the red pen I was using decided to leak. So I added so yellow and darkened it down then on the back I made it look like rust was starting to effect it.
Postby Mustang » Tue Dec 05, 2017 11:45 pm
This is how she look before adding all the parts together.
Postby Mustang » Tue Dec 05, 2017 11:49 pm
The final finished model.
