Airfix 1/24 Harrier
Re: Airfix 1/24 Harrier
Postby steve131 » Fri Jan 13, 2017 9:13 pm
Great idea for the avionics 8-)
Postby Morris » Sat Jan 14, 2017 1:33 pm
I still scroll back to the cockpit pics too, they're awesome!
Posted 'Phase 5' Hachette Easy Rider Captain America
In Very Slow (currently in a holding pattern :()progress 1/18 Pegasus Bell X-1
HKM B17-F Memphis Belle- bomb bay ....BOTY submission
Postby number1 » Sat Jan 14, 2017 9:43 pm
outstanding work Mustang, going to be a superb Harrier when completed
Postby Mustang » Mon Jan 16, 2017 10:16 pm
Cheers guys :)
Postby Mustang » Mon Jan 16, 2017 10:23 pm
Got some done this weekend.
Main wheel bay fitted.
Instruction say white, :roll: mine is a little dirty.
Front wheel bay.
Postby Mustang » Mon Jan 16, 2017 10:37 pm
Next issue front intake areas, the resin parts are about .5 - 1mm lip all the way round.
I looked at sanding down the edges that sit against the main airframe, but that would move the part inwards but would cause issues with the alinement inside.
So instead I'll add some plasticard to the inside of the kit part, this should push the plastic out enough to level up the parts.
I did glue the front of the engine on, but I've decided to remove it and will fit this to the air intakes before fitting the engine in.
Postby Mustang » Sun Jan 22, 2017 6:00 pm
Exhaust ports have had the brass sections added.
Rear set
Front set
Postby Mustang » Sun Jan 22, 2017 6:09 pm
This is the view of the main engine intake, as you can see the internal section doesn't have the centre section or the curved internal wall.
So I've sanded the rear of the front undercarriage rear section down to as much as I can. You can also see that I've added some plasticard to the internal walls this has pushed the walls out so they fit the resin intakes better.
Then I've made the internal section.
Postby Mustang » Sun Jan 22, 2017 6:10 pm
Once installed
Postby Mustang » Sun Jan 22, 2017 6:12 pm
Intakes being glued in place.
As you can see the intakes now fit better.
Postby Mustang » Sun Jan 22, 2017 6:14 pm
? photos removed as I've lost which ones went here after the Photobucket incident
Postby steve131 » Sun Jan 22, 2017 7:01 pm
Very nice work :clap: when you finish this beauty be nice to see your talent on a resin kit ,like Morris Panther :think: 8-)
Postby snapdragon » Sun Jan 22, 2017 9:05 pm
Outstanding work Mustang. Great to see you back at the bench!
Postby number1 » Sun Jan 22, 2017 11:49 pm
snapdragon wrote:Outstanding work Mustang. Great to see you back at the bench!
Same from me :handgestures-thumbup:
Postby Mark » Mon Jan 23, 2017 9:39 am
Looks like your mojo is back :D Great work Mustang !! Love all the additional detailing.
Postby Morris » Mon Jan 23, 2017 2:08 pm
WOW! - that landing gear bay is mental! - Really enjoy this thread...
Postby chill » Mon Jan 23, 2017 3:19 pm
Fantastic work as always.
Postby casper » Mon Jan 23, 2017 8:21 pm
Superb detailing mustang :clap: :clap:
Postby Mustang » Sun Jan 29, 2017 8:24 pm
Thanks everyone. :)
Postby Mustang » Sun Jan 29, 2017 8:32 pm
The next area was the exhaust areas, there's a massive gap.
Which I just didn't like as you can right inside, even with the nozzles on.
Same with the rear ones.
So with some plasticard I've redone the areas.
All four of the nozzles still turn, the plasticard on the front areas go all the way alone the internal wall, this will add some detail to the inside as this area will be slightly open. You want see a lot of it but at least it's there :lol: :lol:
