SA330 Puma 1:32
SA330 Puma 1:32
SA330 Puma 1:32
Postby Mustang » Mon Aug 19, 2019 6:07 pm
Ok.
So as you voted for it here is the SA330 Puma by Matchbox, I did do a 1/72 a couple of years ago in the Tiger scheme
viewtopic.php?f=172&t=6982
But this one will be in its normal military colours.
I bought this kit secondhand for £20 it was listed as complete but on inspection it's missing some of the control levers in the cockpit, so I'll have to sort them out but still not bad for the price I paid for it.
I first had one of these when I was about 8 or 10 it was a Christmas gift from my dads company, they used to do Christmas party's for the employees children (you don't get that today)
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:29 pm
So lets get this diary started.
The box art work has a civilian scheme
But I'll be looking at one of these as my build, there is another version also.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:31 pm
The normal matchbox instructions
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:32 pm
The decals are a bit worse for ware.
But I'll hopefully try and hide any issues later if needed.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:34 pm
So the parts...
The inside already has the pattern for the walls, but I have an idea I'll try when I get there.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:38 pm
The perspex parts
They all look nice for there age except the main front panel, when they moulded this part they moulded a strut across the main window on the outside. But from what I have seen in photos this should have been on the inside. So I'm not sure if to leave it or try and remove it, I now if I try and remove it the perspex will need a lot of sanding to hide the marks and I've tried this a couple of times and failed and if I fail on this it will be wasted.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:41 pm
These parts were all loose in the box.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:43 pm
This is the level of detail in the kit.
Needs some work
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:44 pm
Thanks to Casper for supplying me with some wipers, these will be used on the front side screens.
Still trying to find a slightly larger on for the main screen
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:45 pm
I've had a little shopping for parts.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:46 pm
And I've had a good rummage in my spares box.
Re: SA330 Puma
Postby Mustang » Sat Aug 31, 2019 11:49 pm
The first area is of course the cockpit, and as you can see from the photo theres some bits missing.
These where just dry fitted for the photo, all I need to do now is possible redo the seats and redo/make new control levers.
I'll be back once I've finished :angry-banghead: :angry-banghead: :angry-banghead:
Re: SA330 Puma
Postby casper » Sun Sep 01, 2019 3:31 am
Great start Ian :) never built a Matchbox kit before what's the quality like, It looks fairly big for a 1/32 scale as well. You did a fantastic job on the last Puma mate with the foil interior brilliant :clap: watching closely :)
mark
Re: SA330 Puma
Postby Mustang » Sun Sep 01, 2019 1:05 pm
Hi Mark, thanks for dropping by.
Matchbox kits are not that bad for there age seeing as they where 1970-80 kits, a lot of there moulds where brought by Revell who did some enhancement like on this kit they redid the seat and gave them runners and more detail instead of just a flat side like this one has.
If I had a choose between Matchbox and Revell back then it would have been Matchbox only issue was they only really did small military kits.
As to size this piece is 9.5" long
So quit a beast, one reason why I stow my blades if I can, plus I have another 4 or 5 helicopter at this scale to do :roll:
I have some ideas for the interior like the last one, but for some reason it seams harder to do this one then it was to do the 1/72 version :think: my be I'm over :think: what I can do to it.
Re: SA330 Puma
Postby Mark » Sun Sep 01, 2019 3:34 pm
That's a nice big kit. I recall that Matchbox weren't bad kits. Far better than Revell at the time. Looking forward to seeing what you do with this one.
Re: SA330 Puma
Postby Mustang » Tue Sep 03, 2019 11:22 pm
Thanks Mark for looking in.
Spent a little time on this today still not sure what if anything I'll do to the seat sides. so I looked at the joystick which I only had one of so I needed to make one but I stead made two new ones.
Did a bit of research and these where the closest control units to what the Puma used.
Re: SA330 Puma
Postby Mustang » Tue Sep 03, 2019 11:28 pm
I also looked at the seats and decided to remove the seat belts and replace them.
As the kit comes except for the front seat section which I file'd out.
Removed the moulded belts
And will be using these instead, once I've decided what I'm doing with the seats.
Theres 23 parts to make these little (I must not use naughty words), there not the right ones I know but there not far off.
Re: SA330 Puma
Postby Mustang » Sat Sep 07, 2019 10:10 pm
Seats finally decided what I was going to do with them.
First up cut them down, so removed some from the back and the bottom parts.
Then made some new seat frames.
Re: SA330 Puma
Postby Mustang » Sat Sep 07, 2019 10:12 pm
Old seat.
New seat.
Add some brass rod to the rear and new runners.
Re: SA330 Puma
Postby Mustang » Sat Sep 07, 2019 10:16 pm
Stage one made
New collectives and throttle control's and new cyclics
