SA330 Puma 1:32
Re: SA330 Puma 1:32
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:44 pm
Missing pilots step.
Just measured the decal thats meant to be the step and cut out a small slot.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:46 pm
The two front probes that sit either side of the cockpit where just moulded on.
So replaced with some brass rod.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:47 pm
Then picked out some more little details.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:48 pm
Fuel dump pipes.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:49 pm
Nav lights
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:50 pm
Booster pump access are missing
Re: SA330 Puma 1:32
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:51 pm
Hydraulic and break lines fitted to the two rear wheels.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:53 pm
Tie downs didn't look that great.
Plus missing from the rear wheel covers.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:54 pm
Missing hole from the upper section, so drilled and filed.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:55 pm
Internal wall missing from engine bays.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 12:59 pm
And at the moment I'm looking at the two TURBOMECA TURBINE 3C4 JET ENGINES
Thats what you get in the kit.
Re: SA330 Puma 1:32
Postby Mustang » Mon Dec 02, 2019 1:07 pm
Have to say the 1/32 Matchbox Puma sa 330 kit isn't really that bad for its age. The detail of the rivets and other bits is really good, its just a shame that no one has ever done a aftermarket set of it.
Revell did buy Matchbox moulds for this kit when Matchbox closed, and they made a couple of other examples one of which I might look at as I've managed to get a different set of decals for this model.
But in order to use them I would need to scratch build new front air intakes and a complete build of the front nose cone unit which looks simple as its just squares and pipes and two aerials.
But I'm not 100% sure at the moment as it would be a complete black with a tiger on the rear as from the Tiger meet from XW224 of 230 Squadron, RIAT 1991.
https://commons.m.wikimedia.org/wiki/Fi ... 37044.jpeg
Re: SA330 Puma 1:32
Postby number1 » Mon Dec 02, 2019 4:30 pm
I see your really going to town on this one, watching with great interest as to what you improve next :clap: :clap: :clap:
Re: SA330 Puma 1:32
Postby Mark » Mon Dec 02, 2019 5:42 pm
Loving all the detail on this Ian. You must be putting a lot of researching the project, and it's certainly paying off!
Re: SA330 Puma 1:32
Postby steve131 » Mon Dec 02, 2019 7:14 pm
Great work.
Re: SA330 Puma 1:32
Postby Morris » Mon Dec 02, 2019 7:27 pm
WOWED! Detailing city ! Awesome ... :clap:
Hachette Spitfire Mk1a partworks up to including issues 43-46
DeAgonstini Ford GT40 part work pack 8
Agora Models 427 AC Cobra pack 2
Posting some Lost in Space threads..
Re: SA330 Puma 1:32
Postby Mustang » Fri Dec 06, 2019 4:51 pm
number1 wrote:I see your really going to town on this one, watching with great interest as to what you improve next :clap: :clap: :clap:
Hi N1, I think I need to stop buying old kits between this and the Harrier I've never done so much scratch building.
Got to the point I need to build some standard kits just to restock my spares box :laughing-rolling: :laughing-rolling:
Re: SA330 Puma 1:32
Postby Mustang » Fri Dec 06, 2019 4:54 pm
Mark wrote:Loving all the detail on this Ian. You must be putting a lot of researching the project, and it's certainly paying off!
Cheers Mark, I've downloaded so many photos my iPad ran out of space :( so had to transfer them to my other tablet. I managed to find a company that repairs some of the engine parts and they very kindly sent me photos. :)
Re: SA330 Puma 1:32
Postby Mustang » Fri Dec 06, 2019 4:58 pm
steve131 wrote:Great work.
Cheers Steve. It's been fun trying to workout how to make the bits I wanted. Still have to work on fire wall, rotor unit, rotor head, stow the blades and rear tail unit. But I can't put the cockpit in until I've worked all that out in case I need to add weights to counteract the blades. :think: I have designed and printed new rotor blade fixtures where the blades join the head unit but still building up the nerve to cut the blades as once cut no going back :pray:
