A trio of triplanes - RB, plus Blue Max finished
Postby Morris » Wed Jul 01, 2020 10:22 pm
I am going to try to build a Revell 1/28 scale Fokker DR1 as the Blue Max movie Triplane. Here's some movie stills....
Hachette Spitfire Mk1a partworks up to including issues 43-46
DeAgonstini Ford GT40 part work pack 8
Agora Models 427 AC Cobra pack 2
Posting some Lost in Space threads..
Re: The Blue Max Movie Fokker Triplane
Postby Morris » Wed Jul 01, 2020 10:42 pm
A few bits and bobs I've started on.....whilst waiting on some aftermarket stuff from Tom's Modelworks and others...The first 2 pictures are the fuselage halves interiors that I will grind/sand smooth... :D
A trio of triplanes - early & late RB, plus Blue Max film
Postby Morris » Wed Jul 01, 2020 10:53 pm
Continued with the cockpit and other bits I can build while waiting on the aftermarket stuff..
Postby Morris » Thu Jul 02, 2020 10:12 pm
Worked on opening the engine cowling similar to the movie plane. Then I tried to simulate the fixed radial engine and it's reversed exhaust manifold. (The actual DR1's had rotating engines )
Postby number1 » Fri Jul 03, 2020 12:15 am
Blimy Morris, is there no stopping you? :laughing-rolling: interested in how you do the camouflage on this one! The engine looks good, apart from the exhaust is it how it comes out of the box?
Postby Morris » Fri Jul 03, 2020 12:53 am
number1 wrote:Blimy Morris, is there no stopping you? :laughing-rolling: interested in how you do the camouflage on this one! The engine looks good, apart from the exhaust is it how it comes out of the box?
Thanks - I scratch built the lower exhaust to match the movie version :)
Postby steve131 » Fri Jul 03, 2020 12:33 pm
Good film ,like Revell kits myself .I note the fuselage was red plastic was it a Von Richthofen kit?
Postby Morris » Fri Jul 03, 2020 2:01 pm
steve131 wrote:Good film ,like Revell kits myself .I note the fuselage was red plastic was it a Von Richthofen kit?
Yes sir, the good old Revell one, Red Baron. I have a few of them. I am going to do the iconic version also(the Red and white scheme he never really used, but it's the most published one ) when I finish the Blue Max one...
Anyway, added my home made decal work and continued to detail on the front cowling...the prop I painted I was a bit disappointed with - thinking about getting an aftermarket one...
Postby Morris » Sat Jul 04, 2020 11:51 am
Worked on the landing gear assembly :
Postby Morris » Sat Jul 04, 2020 10:18 pm
Worked on the tail and lower most wing today....
Postby Morris » Sat Jul 11, 2020 1:45 am
As I'm still waiting on some upgrade parts for the Blue Max plane, I built one of Richthofen' Triplanes straight out of the box in the first livery...still have some rigging left to do. Also the decals were extremely old and brittle - the covering I used to hold them together silvered badly...got to see if I can sort that :? :(
Re: The Blue Max Movie Fokker Triplane(& others)
Postby Morris » Sat Jul 11, 2020 5:53 pm
Finished the iconic Red Baron DR1 - straight out of the box except for EZ line, some florists wire and I trimmed the engine cowling open more.....decals were a pain due to their age, very brittle..
Postby Morris » Sat Jul 11, 2020 6:47 pm
Now back to the Blue Max DR1 ....
Postby Morris » Wed Jul 15, 2020 7:29 pm
Bit more done on George Peppard's Triplane - :)
Postby number1 » Thu Jul 16, 2020 3:47 pm
Decals look amazing, could you have made replacements for the red one?
Postby Morris » Thu Jul 16, 2020 6:16 pm
number1 wrote:Decals look amazing, could you have made replacements for the red one?
Yes, but I stuck with salvaging the old ones out of stubbornness :?
Postby number1 » Fri Jul 17, 2020 9:34 am
Ha, a man after my own heart!
Postby Morris » Fri Jul 24, 2020 8:29 am
Sorted the underside mistake and worked on the cockpit .....
Postby Morris » Fri Jul 24, 2020 8:40 am
Then finished the upper logenze decal work :D
Postby steve131 » Fri Jul 24, 2020 6:32 pm
Coming on nicely.
