!/35 Italeri S-100 Schnellboot
Postby ojays » Sat Sep 21, 2013 8:27 pm
As explained in my intro story, I returned to our obsession back in 2011 after a 45+yr break.
This is an on-off build and I don't have a particular build sequence, just doing what I want when I can!
I have had an interest in the German e-boats since a child, when I read stories and saw pictures of them in the comics (Lion/Tiger/Eagle) my father used to bring me every Friday.
I always found them more menacing and powerful looking than the British & American MTB's of the time.
Now in the position (retired) to have the time, I purchased this kit back in Nov 2011. I spent some time collecting several Photo-Etch sets, an AFV 20mm Quad Flak Vierling kit + PE kit for that also, + several other aftermarket ancillaries.
In all there were over 1100 parts to try to put together, I knew this was not going to be a quick build, especially as I intend it to be a working boot with motors(3) and radio Control.
It isn't my goal to represent a particular craft, just a well used weapon of war!
I hope you enjoy as much as I have building it so far!
Were it all started!
Just some of the 600 + parts!
Some more. This Kit is BIG!
AFV 20mm Flak Vierling + Some of the PE.
Hull Assembled & Coffee Time!
Prop Shaft Cut-outs For Stainless Tubes!
Prop Tubes & Brass Bearings Fitted
Rudder Mods!
Oiling Tubes Fitted!
Central Hatch With Micro Magnets For Securing!
Stern Hatch Test Fitting!
Stern Hatch For Access To Rudders Cut Out!
Stern Hatch In Position!
3x400 Can Motor Module Fitted!
Sliding Servo Module Rails!
Sliding Servo Module For Luursen Efekt On Rudders!
Sliding Servo Module Fitted!
Removable Main Deck Hatch!
Removable Forward Deck Hatch!
Replacing Rivets damaged When Sanding!
Some Of The Many Photo Etch Parts!
20mm Flak Vierling In Assembly!
20 mm Flak Vierling Completed!
Slowly Slowly Coming Together!
20mm Flak Vierling Trial Fit!
Cammett Aftermarket Skullcap Bridge & Dinghies!
Cammett Bridge After Some Work.
I will post some more when I have them sorted out!
Gregg
ojays
Re: !/35 Italeri S-100 Schnellboot
Postby Mark » Sat Sep 21, 2013 11:38 pm
Very impressive Gregg. Your weathering is brilliant ! :clap: :clap: :clap:
Postby Eric » Sun Sep 22, 2013 6:59 am
Brilliant!
Well done Gregg, I see that a 45 year lay off hasn't reduced your skill levels!
Postby number1 » Sun Sep 22, 2013 4:49 pm
Have to agree your doing a brilliant job, weathering is just right to my mind, a "K" for sharing with us
Postby steve131 » Sun Sep 22, 2013 7:37 pm
K awarded from myself as well, are you going to see Kevin Wheatcrofts when it is finished.
Postby ojays » Sun Sep 22, 2013 10:38 pm
Many thanks for the positive comments guys.
A couple of question though.
What does the 'K' represent & who is this gentleman 'Kevin Wheatcroft' ?
regards
Gregg
ojays
Postby number1 » Sun Sep 22, 2013 10:54 pm
Hope this answers your question on Ks
Karma, or K's by Mark » Mon Sep 12, 2011 10:04
As we have quite a few new members, I thought I'd just explain the Karma system. You can give good and bad Karma, which is either praising a good post, or registering disapproval of a bad post.
To give good Karma, click the green thumbs up icon which is below the poster's name of the right hand side. To give bad Karma (aka smiting a post) click the red thumbs down icon.
There are limits on how you can give Karma. You can only give Karma once per hour. You can only give one Karma point to somebody at a time. I.e. Give a Karma to person A, and then you have to give a K to somebody else before you can give another to person A. This is a new feature just added to the forum to see how it goes. You have to have made 5 posts before you can give Karma.
You can give good or bad Karma for whatever reason you like, and you don't have to explain yourself. It could be a particularly helpful post, a good joke, admitting to a monumental foul-up. Whatever you think deserves it.
Cheers Mark
I do'nt know the answer to your last question.
Postby ojays » Sun Sep 22, 2013 11:04 pm
Cheers for that Mark, I THINK I understand it. :lol:
Regards
Gregg
ojays
Postby steve131 » Mon Sep 23, 2013 9:55 pm
Hello Gregg ,Kevin Wheatcroft owns the only E boat left in existence and is currently having it restored to ww2 spec. He owns Donnington race track and has an extensive collection of WW2 A F V Google him and E boats. :D
Postby ojays » Mon Sep 23, 2013 11:05 pm
steve131 wrote:Hello Gregg ,Kevin Wheatcroft owns the only E boat left in existence and is currently having it restored to ww2 spec. He owns Donnington race track and has an extensive collection of WW2 A F V Google him and E boats. :D
Hi Steve, I presume you mean S-130, of operation Tiger infamy!
I wasn't aware of the owners name, however I have been following this build on the net!
Regards
Gregg
ojays
Postby steve131 » Tue Sep 24, 2013 8:03 am
Yes that's the one being restored in Cornwall, seen a couple of programmes on History channel about its progress.
Postby baby_astons » Tue Sep 24, 2013 9:04 am
a superb build, looking forward to more 8-)
Postby Sparbucks » Tue Sep 24, 2013 10:17 am
baby_astons wrote:a superb build, looking forward to more 8-)
I'm with BA and all the other applaudees ( :clap: ) on this one. Superb build. 'K' awarded!
Peter
Ongoing builds: Heller Super Constellation conversion, unfinished Airfix Bentley and unfinished Revel Ar196
Recently Acquired Stash: AMT 1/16 Shelby Cobra, Tamiya 1/20 Honda F-1 RA272, Minicraft 1/16 1955 300SL Gull Wing Mercedes plus much, much more!
Sparbucks
Postby ojays » Wed Sep 25, 2013 5:58 pm
As this Boot is going to be handled regularly, I realised that many of the really thin/fragile plastic railings etc., would be susceptible breakage.
This in mind I replaced the Stanchions and depression rails with brass tubing, also correcting some of the rails that were of an incorrect shape. The forward 20mm flak-kanon is inside a tub that is actually incorrect in scale, so a new one was constructed and fitted.
The 20mm Quad Flak-Vierling required a pedestal to mount it on, this and the previous mods following plans acquired from (http://www.rpalmacci). who supplies many amazing scale plans for the Shnellboote.
Some more weathering was also done when I got bored with the metal bending/soldering!
Flak Tub Mods.
Flak Tub & Pedestal Mods.
Flak Tub Rivets.
Flak Tub Mods.
Brass Tube Depression Rails & Flak Pedestal.
Brass Tube Depression Rails.
Weathering.
Weathering.
Weathering.
Gregg
ojays
Postby ojays » Mon Nov 25, 2013 9:49 pm
Some of the work carried out in the last week or so.
Coat of Future to crew etc. to seal prior to Matt Varnish, new mines set from Scale Warship Shop started.
Mines 4.JPG (47.86 KiB) Viewed 12236 times
Mines 11.JPG (26.88 KiB) Viewed 12236 times
Crew Positions 17.JPG (49.47 KiB) Viewed 12236 times
Crew Positions 10.JPG (33.13 KiB) Viewed 12236 times
Torps Painted.JPG (29.2 KiB) Viewed 12236 times
Crew Positions 2.JPG (36.65 KiB) Viewed 12236 times
Crew Positions 13.JPG (35.29 KiB) Viewed 12236 times
ojays
Postby maximus2012 » Tue Nov 26, 2013 9:46 am
Fantastic job that. "K" well deserved, wish the would bring out the early type in that scale(the one you get from airfix is at 1/72) I would have one of them.
maximus2012
Postby ojays » Tue Nov 26, 2013 11:44 am
maximus2012 wrote:Fantastic job that. "K" well deserved, wish the would bring out the early type in that scale(the one you get from airfix is at 1/72) I would have one of them.
Many thanks for you welcome comments.
You can make the earlier version in 1/35, as that is my next project.
I bought a (very badly nearly made/destroyed) Schnellboote off e-bay quite cheaply to convert.
I am in the process of purchasing the excellent plans for converting the 1/35 Italeri S100 from Robert at http://www.rpalmacci.free.fr
I have used his plans to correct some of the items on my boote, and found them to be very easy to use and worthwhile for detailing, as can be seen in some of the photo's above.
They are not expensive, and if you are into plasti-card bashing shouldn't be too much of a chore.
You can view the plans on his website before purchase, to see if that is the road you may want to go.
Gregg
ojays
Postby Sparbucks » Wed Nov 27, 2013 10:47 am
Great build Mr ojays! Have just come into this thread - love the weathering, and it is very nice to meet another rivet driller! How many did you break on the Flak tub?
'K' awarded :clap:
Peter
Sparbucks
Postby ojays » Wed Nov 27, 2013 11:04 am
Sparbucks wrote:Great build Mr ojays! Have just come into this thread - love the weathering, and it is very nice to meet another rivet driller! How many did you break on the Flak tub?
'K' awarded :clap:
Peter
Thanks for the positive comments Peter,
As to the rivets, I cheated and used 'Archer' resin rivets. So easy to use and not expensive.
Gregg
ojays
Postby Sparbucks » Wed Nov 27, 2013 2:23 pm
ojays wrote:Thanks for the positive comments Peter,
:o :(
Sparbucks
