San Francisco Cross Section
Re: San Francisco Cross Section
Postby Mustang » Thu Sep 05, 2019 5:12 pm
casper wrote:That looks excellent :clap: :clap:
and so much smaller than I thought it was Ian, thanks for the thumb scale :D
Hi Mark, measured it today as it stands on the stand
140mm long but this includes the exstra ends I added, so the original lenght would have been 120mm
155mm wide
165mm high
Postby Mark » Thu Sep 05, 2019 5:49 pm
Enjoying this very much Ian. As an aside, have you built the DeAg Victory cross section. If not, I'm sure you'd enjoy it. It's one of the best cross section kits (if not the best) that I've seen.
Postby Mustang » Thu Sep 05, 2019 6:08 pm
Hi Mark, thanks for looking in as to the DeAg version no I don't have that one, I have the Corel Verison of the cross section. I opened it and looked at the instructions some 20+ years ago and thought I needed more practise before I started it but I'll start in one day :think:
Postby Mustang » Sat Sep 14, 2019 10:57 pm
So I've repaired my blunder.
And added internal sections
Then added the final layer.
Dry fitted the outer porthole casing.
Postby Mustang » Sat Sep 28, 2019 9:46 pm
While adding the outer bands to the hull.
The centre clamp must have moved while the glue was setting as I ended up with a nice bow in the wooden strip. So I had to strip the plank off.
And then remove some of the strips.
Then glue new strips in.
Postby casper » Sat Sep 28, 2019 10:12 pm
porthole casing really look good and finishes the hole off perfectly Ian :clap:
Postby Mustang » Fri Nov 08, 2019 11:19 pm
Thank you Mark.
Postby Mustang » Fri Nov 08, 2019 11:22 pm
So after repairing the mistake I made :angry-banghead: :angry-banghead:
The model has moved on a bit.
The instructions tell you to make two stairs as in the photos.
How any model person is meant to get up and down them with taking there heads of is a :laughing-rolling:
Postby Mustang » Fri Nov 08, 2019 11:25 pm
So after some thinking and look at other kits I have, I decided to do this it not 100% correct but look way better.
The only issue is I don't think they would have had the stairs leaning against the granting.
Postby Mustang » Fri Nov 08, 2019 11:27 pm
I have added the small bits where the stairs lean against the grating.
Then added the steps to the hull.
Postby Mustang » Fri Nov 08, 2019 11:28 pm
Added all the fixed parts to the upper deck.
Postby Mustang » Fri Nov 08, 2019 11:29 pm
And added the counter weights to the hull, again something not included with the kit.
Postby Mustang » Fri Nov 08, 2019 11:31 pm
So just to compare how I've adapted the hull.
The kit.
My way.
:think: :think: :think:
Postby number1 » Fri Nov 08, 2019 11:41 pm
Massive improvement over the original, your right about the angle of the steps, they are not far of vertical if I remember correctly.
Postby MI5 » Sun Nov 10, 2019 5:48 pm
I love Cross sections and you are making a cracking job of this one.
Martyn
MI5
Postby Mustang » Sun Nov 17, 2019 7:28 pm
Hi No1 and MI5 thank you for looking in and for the comments :)
Postby Mustang » Sun Nov 17, 2019 7:32 pm
Got the barrels and buckets done.
Done the last four cannons
Postby Mustang » Sun Nov 17, 2019 7:35 pm
Primered and painted the metal parts, the gun door where two parts I just glued them to a angle.
Also gave the Cannons a light wash to remove the bling.
Postby Mustang » Sun Nov 17, 2019 7:36 pm
Balls anyone...
