Polar Lights 1:25 scale 1966 TV series Batmobile
Re: Polar Lights 1:25 scale 1966 TV series Batmobile
Postby Paul » Sat Mar 16, 2013 8:28 am
casper wrote:great shot of the chassis Paul. The original Batmobile had a Matt finish but was later changed to gloss black.
You have some good detail of the turbine and drive shaft Paul
Hi Casp,
I'm going to have to find some reference pics for the colours :)
Postby Paul » Sat Mar 16, 2013 1:49 pm
As I've not yet sorted out all the colours, mainly the Chevy red, I'm just going to see what little I can do in the interim.
Not only that, I need to stock up on paint as well !
Postby Paul » Sat Mar 16, 2013 1:54 pm
Paul wrote:
baby_astons wrote:paul the clear parts cannot be messed up then :oops: sorry I'm so nasty today...
I was just about to start complaining that you've bought a fully painted model but the special edition (and the fever as I'm in bed again) has calmed me down ;)
Hi BA,
The basic version is mainly painted, though not e.g. the fire extinguisher and the silver behind the seats etc
Also, a correction of the clear parts, as the windscreens need silver adding on the edges :oops:
Hi BA,
Correction again.......
Even with this version, apart from the body shell, nearly everything needs a paint job ! :D
Postby Paul » Sat Mar 16, 2013 4:31 pm
A pic of the wheels and the tyres, hopefully showung all views:
The Bat spinners can't be fitted until the wheels are fitted to the chassis.
I think the chrome is fine for this size of model, so I hope the rest of the chrome parts are fine as well !
Postby Paul » Sat Mar 16, 2013 5:06 pm
I've fitted the floorboards and transmission tunnel as a dry fit to the chassis.
I'm thinking on spraying them all in one go as I think they will all be matt or satin black....
Any comments or thoughts are most welcome on this !
Postby Paul » Sun Mar 17, 2013 2:55 pm
Paul wrote:A pic of the wheels and the tyres, hopefully showung all views:
On the Deluxe version, the brake discs are also supplied, though not on this version
Postby Paul » Sun Mar 17, 2013 4:25 pm
I've decided to paint the steering wheel on the spruce for the silver (not too sure if incorrect or not!), though it will need to be taken off it to paint the black:
On the Deluxe version, this steering wheel, and another one is available - there are so many options on the Deluxe version of the car !
For the Deluxe version, I'll go with the other steering wheel which is like the one on the 1:18 scale die cast model
To give you an idea of size, the steering wheel is a lot more smaller than a 1p piece.
Postby Paul » Sun Apr 07, 2013 12:22 pm
The chassis has been sprayed in Humbrol 85 (coal black) which is a satin finish and I've also started to paint in the underneath of the Turbine engine in silver:
Postby Paul » Sun Apr 07, 2013 4:54 pm
A bit of a first paint job on the chassis, though it will need another coat and then lining in:
Postby Paul » Fri May 31, 2013 11:26 am
With the other version nearly finished (just need to repainted Robin) I just wonder what I can stuff up with this one ..... :roll: :roll: :roll: :think: :laughing-rolling:
Postby Paul » Fri May 31, 2013 11:44 am
I'm just doing a check list of what I can't stuff up !
Batman and Robin already painted
No V8 or Turbine engine
Bodywork and decals already done
As for the rest, Ah well !!!! :laughing-rolling:
Postby baby_astons » Fri May 31, 2013 1:10 pm
like kennedy said, don't ask what you can stuff up, ask what your cat can stuff up :laughing-rolling:
Postby Paul » Fri May 31, 2013 4:34 pm
baby_astons wrote:like kennedy said, don't ask what you can stuff up, ask what your cat can stuff up :laughing-rolling:
All will be assumed to have been done ..... :laughing-rolling:
Postby morrigan » Fri May 31, 2013 8:26 pm
:laughing-rolling:
Well the it does say snap together on the box.
Still leaves it open as to what or whom will be doing the snapping.
Postby Paul » Sat Jun 01, 2013 10:03 am
Nothing snapped or broken yet ..... :roll: :roll: :roll: :laughing-rolling:
Postby Paul » Mon Jun 03, 2013 6:18 pm
With the seats on this one, I think I'll paint them as I have seen a nice pic of a replica one with red piping on the seats.... :think:
All just a thought at the time though ! :)
Postby Paul » Tue Jun 04, 2013 5:50 pm
I've just sprayed the seats tonight with black, and then the gloss varnish........
The reason being my failure on the Deluxe version, so I'm hoping for another matt finish......
What's the bets that they turn out gloss this time, as they should have done with the DEluxe version .....?! :laughing-rolling:
Postby Paul » Tue Jun 04, 2013 6:06 pm
Paul wrote:I've just sprayed the seats tonight with black, and then the gloss varnish........
Flipping typical, yes I do have a gloss finish on the seats ! :angry-banghead:
Oh well, I'll try lining out later and see what happens ..... :roll: :roll: :roll:
Postby casper » Tue Jun 04, 2013 6:16 pm
did you use the same black base coat on the seats Paul
Postby Paul » Tue Jun 04, 2013 6:25 pm
Hi Casp,
Yes, however, as BA has mentioned before, it's on the drying time.
Today each coat took 15 mins to dry and then the next coat applied.
However, I've just done the red piping on one seat, and hardly any re-lining in is required :D
