Yet another 1/5th scale engine
Postby R2D2 » Sat May 20, 2017 7:08 pm
Came across this in my local charity shop for £10.00. Had to get it!
Re: Yet another 1/5th scale engine
Postby R2D2 » Sat May 20, 2017 7:09 pm
1st contents of box!
Postby R2D2 » Sat May 20, 2017 7:10 pm
2nd contents!
Postby R2D2 » Sat May 20, 2017 7:11 pm
Took off pistons and rods and trimmed.
Postby R2D2 » Sat May 20, 2017 7:12 pm
Piston cranks.
Postby R2D2 » Sat May 20, 2017 7:15 pm
Pistons and rods fitted to crankshaft! The kit says no glueing required however I glued the piston halves together as I recon if not they could become loose and clog up the mechanism!
Postby R2D2 » Sat May 20, 2017 7:16 pm
Lower engine case fitted to lower plate!
Postby R2D2 » Sat May 20, 2017 7:18 pm
Crankshaft with pistons fitted to main engine block and screwed in place!
Postby R2D2 » Sat May 20, 2017 7:24 pm
Top of engine showing pistons!
Postby R2D2 » Sat May 20, 2017 7:26 pm
Cam, Cams, rockers fitted to top of engine block! The red pins on the top of the rods are just a push fit so I glued them to make sure they dont come off!
Postby R2D2 » Sat May 20, 2017 7:27 pm
Underside of valves in cylinder head!
Postby R2D2 » Sat May 20, 2017 7:28 pm
Cardboard cut out to represent gaskett.
Postby R2D2 » Sat May 20, 2017 7:37 pm
Top of engine fitted to main engine block.
Postby R2D2 » Sat May 20, 2017 7:38 pm
Rocker cover fitted in place.
Postby R2D2 » Sat May 20, 2017 7:40 pm
Timming belt fitted in place! The funny orange thing lines up the gears before the belt is fitted.
Postby R2D2 » Sat May 20, 2017 7:41 pm
Belt fitted and jig removed!
Postby R2D2 » Sat May 20, 2017 7:42 pm
Front timing belt cover fitted.
Postby R2D2 » Sat May 20, 2017 7:43 pm
Fan, fan belt, and pully fitteed.
Postby R2D2 » Sat May 20, 2017 7:44 pm
Starter motor fitted. This is a complete ready built unit and is the drive motor which is geared down.
