Halo Master cheif re-paint
Postby casper » Wed Apr 08, 2015 8:02 pm
Yet another sic-fi project for my son Shane and I haven't finished the Terminator yet :roll: :oops: I have the Alclad but my Airbrush is spitting paint :think:
Anyway this is just a repaint of a coin bank my son had as a gift that I have had my eye on it for a while :shifty:
sorry but the first couple of photos didn't turn out too good
Head popped off with a little persuision and Vaseline :)
better picture of the Halo bust
Re: Halo Master cheif re-paint
Postby casper » Wed Apr 08, 2015 8:07 pm
The arms were more difficult to remove so i cut them off with a blade, these will be glued back later
There is a coin slot on the top that needed filling so i used some styrene sheets stuck together and glued that in place and left it to cure
Postby casper » Wed Apr 08, 2015 8:11 pm
This was then filled with Tamiya plastic putty and sanded back when dry
All parts were lightly sanded to get a key for the paint and then washed and dried, then all parts were undercoated grey apart from the gun that comes in two parts.Image
Postby Mustang » Wed Apr 08, 2015 8:13 pm
Bit late now.
But you could have tried hot water poured into the arm sockets, it might have softened the plastic so you could have pulled the arms out.
But anyway back to the idea, I like it it will be a interesting project. :clap: :clap:
Postby casper » Wed Apr 08, 2015 8:18 pm
Hi mustang :) thanks for looking in :D
I did try hot water mate but the plastic is rather brittle but some Vaseline did the job eventually and later i trimmed it to help get it back in later. The arms just wouldn't budge
The helmet had four false plastic lights so i cut and drilled them out to 2mm in order to fit LED,s after final paint
Postby casper » Wed Apr 08, 2015 8:22 pm
I love all the detail to this bust and now all the parts have had a thin coat of Humbrol 56 alluminum you can see how accurate to the Game this really is
Postby Mustang » Wed Apr 08, 2015 8:25 pm
K :clap: :clap: :clap:
It's looking very nice, I do love seeing what you'll be doing.
This and the Terminator are nice little gems you found :clap: :clap:
Postby casper » Wed Apr 08, 2015 8:42 pm
Mustang wrote:K :clap: :clap: :clap:
Thanks Mustang :) I,m looking for a second Terminator to do a factory version
After the aluminium was dry I gave the body armour areas a couple of coats of gloss clear and left them to dry
Thats it for now until my Khaki olive drab arrives for the top coat :)
weather was kind this week
Postby casper » Sat Apr 25, 2015 12:27 pm
Before applying the Humbrol Olive Drab (not Khaki olive drab) I masked up the areas not to be painted and gave the parts a couple of coats of Hairspray
Postby casper » Sat Apr 25, 2015 12:34 pm
About 2 hours later after my afternoon nap i started to add water to the areas that were to be weathered and started to chip at the paint with a stiff brush and scotch-brite pads
The paint was difficult to get working at first and required a lot of water to get it to lift off the aluminium undercoat. I did get a few spots of blue where i overdid the rubbing but these can be touched up later
A little more work and it should look ok
Masking tape removed and some flat black added to the skin suit
Postby casper » Sat Apr 25, 2015 6:21 pm
Some of the paint scratches and chips had Vallejo silver along the edges to give hopefully give some depth, you have to be very careful not to overdo it :think:
Next up a satin clear coat :)
Postby casper » Mon May 04, 2015 6:41 am
Well i tried the satin clear coat but couldn't get the pin-wash to flow very well :think: maybe i should try a clear gloss then add a wash to tone it down a little
I did some more of the black on the arms and body but there are still some areas to finish off.
I also removed the mask from the visor
Dry fit to see how it looks so far :D
Postby casper » Mon May 04, 2015 6:44 am
I want to give the black body suit a weathered look but not sure how to go about it :think:
I was thinking of dry brushing some black gloss or satin on to the raised areas, any suggestions guys :)
Postby Mark » Mon May 04, 2015 10:23 am
Try dry brushing a dark grey to give some highlights. I did that one the gloves of the Cavalier and the YZR-M1. The eye is easily tricked, and it still looks black, but with a bit more texture/contrast.
Postby casper » Mon May 04, 2015 4:50 pm
Mark wrote:Try dry brushing a dark grey to give some highlights. I did that one the gloves of the Cavalier and the YZR-M1. The eye is easily tricked, and it still looks black, but with a bit more texture/contrast.
Thanks for the tip Mark, will try that :)
Ialso want to try a wash so would you recommend a clear gloss coat and would this tone down after as i don't really want a glossy look to the armour
cheers for looking in :)
Postby Mark » Mon May 04, 2015 6:03 pm
I think the only way a wash will work is if you paint the whole armour a dark grey and then use a black wash. I don't think playing with gloss and matt finishes will be very successful, but I could be wrong....... There's nothing wrong with going for a dark grey with a black wash and slightly lighter grey highlights. In fact, black things rarely actually look jet black in real life. Most 'black' things look grey or a dark colour of some sort (probably lots of different colours.)
Try taking a photo of something that is black and looking at it carefully, possibly with the background blanked out.
Postby steve131 » Mon May 04, 2015 8:15 pm
Great work Casper :clap: are you going to do anything to the visor :?:
Postby casper » Tue May 05, 2015 1:13 am
Hi Mark
I was only going to do a wash over the green body armour not the black skin suit areas to add some grime or dirt. I think the dark grey for the black area is a great idea but will try on some scrap first, thanks for your help mate.
Hi steve and thanks for looking in :)
I kept the visor masked up as the surface is nice and smooth, it has good colour but i was thinking of adding gold leaf, not sure if it will work but its worth a try. The visor in the game has a honeycome pattern but that will be difficult to reproduce :think:
I may try doing some parts in gold leaf and some left as is, will decide later when i start to apply it.
Postby Mark » Tue May 05, 2015 3:56 pm
Sorry, misunderstood you on that one. Yes, I'd give it a light coat of clear gloss before adding a wash.
You can always give it a final coat of satin or mat when you've finished.
How about fishnet stockings as a mask to reproduce a honeycomb effect ? Haven't played the game, so not quite sure what you're aiming for.
Postby casper » Tue May 05, 2015 6:57 pm
Hi Mark :)
My fault, I didn't explain it correctly
The honeycomb visor may be too difficult to do so I will just try the gold leaf and see how it looks. Thanks for the tip for the wash mate will try that. ;)
Return to Sci Fi
