A companion for R2-D2
Postby corelki2005 » Thu Aug 03, 2017 2:00 pm
As an interlude from my tiffy build I acquired this as a companion to my 1/2 scale R2-D2
Its made by Bandai
the first pic is the internal frame work, the second shows two of the sections added and the third is the completed unit.
Nick
corelki2005
Re: A companion for R2-D2
Postby casper » Thu Aug 03, 2017 4:39 pm
cool 8-)
Postby Mark » Fri Aug 04, 2017 6:02 am
I saw the finished model in Japan - it looks amazing ! I think there was also an optional lighting set ?
Postby corelki2005 » Fri Aug 04, 2017 10:10 am
Mark wrote:I saw the finished model in Japan - it looks amazing ! I think there was also an optional lighting set ?
There is Mark but for what Bandai want for this, it is expensive for a battery box, on off switch and two leds, and you need 2 of them. (approx. £25 ea.). even then it only lights up the head.
Nick
corelki2005
Postby Mark » Fri Aug 04, 2017 12:52 pm
Good grief ! That's ridiculous !
Postby corelki2005 » Fri Aug 04, 2017 1:01 pm
this is what they look like
Nick
corelki2005
Postby Mark » Sat Aug 05, 2017 6:28 am
You could do a much cheaper diy job easily
Postby corelki2005 » Sat Aug 05, 2017 12:48 pm
Am way ahead of you Mark, have asked de-agostini for issues 57 and 100 of the MF so that I can have lots of lights and it will be remote controlled as well(assuming they have back issues available).
Nick
corelki2005
Return to Sci Fi
