Dazza's 1:16 T34/85
Dazza's 1:16 T34/85
Dazza's 1:16 T34/85
Postby Dazza » Mon Dec 22, 2014 4:39 pm
This is a kit I have started and I will bring this post up to date as to where I am with it now.
I have started my 1:16 T-34/85 by Trumpeter,it is a super detailed kit and I will be adding extras, like a full PE set for interior and exterior, metal barrel and other goodies!!
Next to my 1:35 T-34/85!!
From Left to Right:- 1:16 Trumpeter Kingtiger, 1:16 T-34/85, 1:35 T-34/85
Large box of bits!!
Schumo barrel!
Suspension done.
If at first you don't succeed, never try sky diving!!
Dazza
Re: Dazza's 1:16 T34/85
Postby Dazza » Mon Dec 22, 2014 4:45 pm
Dry fit of wheels and tracks. I am not happy with the tracks so I have some metal ones coming. The suspension is fully working.
Dazza
Postby Dazza » Mon Dec 22, 2014 4:46 pm
Nice detail on this kit. P.E machine gun ammo rack!!!
Dazza
Postby Dazza » Mon Dec 22, 2014 4:47 pm
Test fit of metal tracks.......PERFECT!!!!!!
Dazza
Postby Dazza » Mon Dec 22, 2014 4:49 pm
I have started on the engine and transmission. They are a model all on their own!
Some painting done.
Completed engine
I added some injector pipes made from Friul track wire.
Dazza
Postby Dazza » Mon Dec 22, 2014 4:51 pm
Dry fit of engine and transmission
Dazza
Postby Dazza » Mon Dec 22, 2014 4:52 pm
Engine and transmission are now done.
Dazza
Postby Dazza » Mon Dec 22, 2014 4:53 pm
Some mods done to the upper hull to allow the engine and transmission to be seen.
Dazza
Postby Dazza » Mon Dec 22, 2014 4:55 pm
Engine bay done. Engine fitted next.
Dazza
Postby Dazza » Mon Dec 22, 2014 4:57 pm
Engine and transmission fitted.
Its a shame so much is hidden when the upper hull is on, but I have made sure as many hatches and inspection panels open as possible.
Just a few injector marks to fill in the panels that will be seen!!!
Dazza
Postby Dazza » Mon Dec 22, 2014 4:58 pm
Radiators fitted.
Dazza
Postby Dazza » Mon Dec 22, 2014 5:00 pm
Center bulkhead, ammo boxes and exhausts ready to fit.
Engine and transmission bay completed.
Dazza
Postby Dazza » Mon Dec 22, 2014 5:01 pm
Drivers compartment finished.The gauges came in one of the p.e sets.
Dazza
Postby Dazza » Mon Dec 22, 2014 5:04 pm
I have made a start on some of the sub assemblies and making up some of the PE sets.
Well the barrel was a pain in the ass!!! Its a Schumo barrel designed for this kit, and it didnt fit!!! I had to make a collar out of the original plastic kit part and spend 2 hours sanding it down to make it fit!!! Its done though and looks great!!
I have finished the mods to the rear transmission cover and inspection plate, now ready for primer.
Dazza
Postby steve131 » Mon Dec 22, 2014 5:08 pm
Great work Dazza nice looking kit like your King Tiger also welljell K awarded. :clap:
Postby Mark » Tue Dec 23, 2014 10:16 am
Oh, ejector pin city ! Nice progress so far. The interior weathering is fab !
Postby Dazza » Tue Dec 23, 2014 12:16 pm
The rear of the hull has now been modified to allow the rear engine cover to open. I will probably leave the other covers as a dry fit to allow me to display the engine, but I will ponder this as I go and may modify the hull some more to allow more hatches to open. The last photo is a dry fit of the PE rear panel locating plates.
Dazza
Postby Dazza » Tue Dec 23, 2014 12:17 pm
Rear pe now fitted as well as side fuel tanks. Pe tool box is a dry fit for now, I will fit it after painting the fuel drums.
Dazza
Postby Dazza » Tue Dec 23, 2014 12:22 pm
Prepping the upper hull now to be ready for primer.
Upper hull fittings finished. Primer done and lower hull masked off.
Dazza
Postby Dazza » Tue Dec 23, 2014 12:24 pm
Lower hull now in primer.
Lower hull now in Russian green!! :D
Dazza
