HMB Endeavour Parts
HMB Endeavour Parts
HMB Endeavour Parts
Postby SkyFire » Sat Jan 22, 2011 1:34 am
List of the parts included with each magazine of the HMB Endeavour partwork. I'll add to this so people can see what should be coming with each magazine, can we keep comments to a minimum in this thread, to make it easier to see the parts and find them. :)
Issue #1
1 x Bow Frame Section A
1 x Stem (bow/front end) timber
15 x Ayous Planking Strips
1 x Lower Fordeck A
1 x Starboard (right) Quarter Badge
1 x Port (left) Quarter Badge
Issue #2
30 x Ayous Planking Strips
1 x Bow Frame Section B
1 x Bow Frame Section C
1 x Lower Fordeck B
Issue #3
2 x Mid Section Reinforcing Plates
1 x Mid Section Timber
1 x Bow Frame Section D
3 x 150 x 5 x 5mm Ayous wood Strips
Issue #4
1 x Bow Frame Section E
1 x Bow Frame Section F
1 x Lower Waist Deck A
1 x 300 x 5 x 5mm Ayous wood Strip
Issue #5
1 x Lower Waist Deck B
2 x Mid-section Reinforcing Plates
1 x Forecastle Deck
Issue #6
1 x Bow Frame Section G
2 x Stern Section Reinforcing Plates
Issue #7
1 x Bow Frame Section H
1 x Stern (rear) Section Timber
Issue #8
1 x Bow Frame Section I
1 x Lower Stern Deck A
Issue #9
1 x Lower Stern Deck B
2 x 100 x 4 x 1mm Ayous wood Strips
2 x Stairway Uprights
Issue #10
45 x Ayous Planking Strips
1 x 300 x 4 x 2mm Ayous wood Strip
1 x Waist Deck A
Issue #11
1 x 300 x 2 x 2mm Ayous wood Strip
1 x Waist Deck B
Issue #12
40 x Ayous Planking Strips
1 x 300 x 2 x 5mm Ayous wood Strip
1 x Waist Deck Bulkhead
Issue #13
1 x 300 x 2 x 4mm Ayous wood Strip
1 x Stern Deck A
Issue #14
1 x Bow Frame Section J
1 x Stern Deck B
Issue #15
1 x Pin Pushing Tool
100 x Pins (0.65 x 10mm brass plated) - Parts count approximate.
Issue #16
1 x 100 x 4 x 1mm Ayous wood Strips
2 x Stairway Uprights (stringers)
2 x Bow Exterior Bulwarks
Issue #17
1 x 20 x 20mm Ayous Wood Block
5 x Bow Interior Bulwark Framework
Issue #18
1 x 300 x 4 x 4mm Ayous wood Strip
Issue #19
4 x Stern Frame K
Issue #20
2 x 300 x 4 x 4mm Ayous wood Strips
2 x Stern Bulwarks
Issue #21
2 x 300 x 8 x 0.6mm Sapelli Lining Sheet
1 x Capstan
150 x Pins (0.65 x 10mm brass plated) - Parts count approximate.
Issue #22
1 x Stern Frame L
Issue #23
2 x Waist Bulwark Frames
Issue #24
2 x 300 x 4 x 2mm Ayous wood Strip
2 x Swivel Guns
Issue #25
20 x 300 x 5 x 2mm Ayous wood Strips
Issue #26
1 x Gun Carriage
1 x 4 Pounder Gun
1 x Brass Rod (100 mm x 1.5 mm diameter)
4 x Gun Carriage wheel
Issue #27
Issue #28
Issue #29
1 x Anchor, (shaft, arms and flukes)
1 x Brass strip (100 x 3mm)
2 x 8mm Brass rings
Issue #30
Issue #31
bItuHpa' BIHeghjaj - (Death before shame). ortaS bIr jablu'DI', reH QaQqu' nay' - Revenge is a dish best served cold. Qapla'!
SkyFire
Re: HMB Endeavour Parts
Postby SkyFire » Mon Feb 07, 2011 7:02 am
Issue #32
3 x 300 x 4 x 1mm Ayous wood Strip
2 x Rudder Keel reinforcement
1 x Fore hatchway hood - eight push out pieces
25 x Eyebolts (brass plated) - Parts count approximate.
Issue #33
Issue #34
Issue #35
SkyFire
Postby SkyFire » Mon Feb 28, 2011 12:45 am
Issue #36
2 x 300 x 4 x 1mm Ayous wood Strip
3 x 300 x 7 x 2mm Ayous wood Strip
1 x Quarterdeck hatchway hood - eight push out pieces
20 x Brass Ring (6mm diameter)
Issue #37
Issue #38
2 x Brass strip (100 x 3mm)
1 X Brown cotton thread (1.5mm diameter)
SkyFire
Postby SkyFire » Wed Mar 30, 2011 2:58 am
Issue #39
1 x Brass hinges, supports and lantern
Issue #40
Issue #41
Issue #42
1 x False keel bow reinforcements (five pieces)
SkyFire
Postby SkyFire » Fri Jun 03, 2011 6:17 am
Issue #43
Issue #44
1 x False keel bow reinforcements (five pieces F - J)
1 x False keel bow reinforcements (five piece E)
Issue #45
Issue #46
2 x 300 x 3 x 2mm Ayous wood Strip
1 x False keel stern reinforcements
Issue #47
2 x False keel stern reinforcements
Issue #48
3 x 300 x 6 x 2mm Ayous wood Strip
35 x 250 x 5 x 0.6mm Ayous wood sheating strip
10 x Belaying cleat
Issue #49
10 x Belaying cleat
Issue #50 - Halfway
2 x 300 x 2 x 2mm Ayous wood Strips
5 x 300 x 6 x 2mm Ayous wood Strip
5 x Belaying cleat
Issue #51
2 x Swivel guns (falconet)
60 x 250 x 5 x 0.6mm Ayous wood sheating strip
60 x 250 x 5 x 0.6mm Sapelli wood sheating strip
25 x Beads (swivel gun handles and parrel rope rigging trucks)
SkyFire
Postby SkyFire » Tue Jun 28, 2011 5:48 am
Issue #52
2 x 300 x 2 x 2mm Ayous wood strip
6 x 300 x 6 x 2mm Ayous wood strip
5 x Belaying cleat
35 x 250 x 5 x 0.6mm Sapelli sheathing strip
1 x 300 x 5 x 3mm Ayous wood strip
Issue #53
1 x 300 x 5 x 5mm Ayous wood strip
2 x 300 x 5 x 3mm Ayous wood strip
Issue #54
10 x Rigging block (5mm)
15 x Rigging dead eye (4mm)
Issue #55
2 x Raw cotton thread (0.15mm)
1 x Brown cotton thread (0.8mm)
SkyFire
Postby SkyFire » Mon Jul 25, 2011 4:31 am
Issue #56
25 x Eyebolt
10 x Belaying Cleat
8 x Rudder Hinge
1 x Brass wire (1.5mm diameter)
Issue #57
10 x Belaying Cleat
2 x 300 x 10 x 2mm Ayous wood strip
1 x Stem and keal (three pieces)
Issue #58
1 x 300 x 3 x 2mm Ayous wood strip
20 x Rigging block (4mm)
1 x Rudder, stern and keel (three pieces)
Issue #59
5 x Belaying Cleat
10 x Rigging block (4mm)
2 x 300 x 10 x 0.6mm Ayous wood strip
1 x False stern transom (two pieces)
1 x Brown cotton thread (0.5mm)
SkyFire
Postby SkyFire » Mon Aug 22, 2011 5:23 am
Issue #60
2 x 300 x 5 x 5mm Ayous wood strip
1 x 300 x 4 x 4mm Ayous wood strip
2 x Pulley Wheels
1 x Stern Transom (two pieces)
Issue #61
4 x 300 x 5 x 2mm Ayous wood strip
2 x Pulley Wheels
1 x Bow Gunwale (three pieces)
6 x 300 x 5 x 1mm Ayous wood strip
1 x 300 x 6 x 1mm Ayous wood strip
1 x Oven Flue
Issue #62
15 x Belaying Cleat
1 x Raw cotton thread (0.15mm)
1 x Breakwater (six pieces)
Issue #63
10 x pulley block (4mm)
1 x windlass (six pieces)
1 x windlass gear
1 x windlass large winch
1 x windlass small winch
SkyFire
Postby SkyFire » Wed Sep 14, 2011 3:22 am
Issue #64
1 x Windlass large winch
1 x Windlass small winch
1 x Belfry
1 x Ships bell
2 x Windlass figure
5 x Dead eye block (7mm)
Issue #65
1 x 300 x 2 x 2mm Ayous wood strip
25 x Eyebolt
1 x Taffarel decoration and stern windows
1 x Tiller bridge and hatch cap (nine pieces)
Issue #66
2 x Gun carriage
2 x 4 pounder gun
1 x Brass rod (100mm x 1.5mm dimater)
8 x Gun carriage wheel
10 x Rigging blocks (4mm)
Issue #67
2 x Gun carriage
2 x 4 pounder gun
5 x Rigging blocks (4mm)
SkyFire
Postby SkyFire » Mon Oct 17, 2011 8:12 am
Issue #68
10 x Belaying cleat
20 x Rigging blocks (4mm)
1 x Channels (six pieces)
Issue #69
5 x Belaying cleat
1 x Lateral ports (12 pieces)
25 x small brass ring
1 x Brass wire (1mm diameter)
5 x column
Issue #70
1 x Gun Carriage
1 x 4 Pounder Gun
5 x Belaying cleat
5 x Belaying pin
5 x Rigging dead eye (5mm)
Issue #71
5 x Belaying cleat
10 pulley block (4mm)
1 x Skylight (six pieces)
1 x Skylight pane
1 x Steering wheel
SkyFire
Postby SkyFire » Mon Nov 14, 2011 5:55 am
Issue #72
1 x Binnacle (eight pieces)
1 x Steering wheel barrel
2 x Steering wheel support posts
Issue #73
1 x Brass wire (1 mm diameter)
1 x Starboard stern decoration
1 x Port stern decoration
1 x Starboard stern figurine
1 x Port stern figurine
4 x Stern window mullion decoration
Issue #74
1 x Brass strip (100 x 3 mm)
10 x Rigging dead eye (4mm)
1 x Mizzen mast hole trim (small)
1 x Foremast hole trim (medium)
1 x Mainmast hole trim (large)
Issue #75
25 x Eyebolt
10 x Rigging dead eye (5mm)
2 x Bilge pump
2 x Level support
SkyFire
Postby SkyFire » Thu Dec 08, 2011 8:17 am
Issue #76
1 x 100 x 4 x 1mm Ayous wood strip
5 x Belaying cleat
20 x pulley block (4mm)
1 x Belfry
2 x Bilge pump
2 Lever support
Issue #77
2 x 300 x 4 x 2mm Ayous wood strip
1 x Lantern base
1 x Lantern cap
1 x chain
Issue #78
2 x 300 x 5 x 2mm Ayous wood strip
10 x Belaying cleat
1 x Channel standards (26 pieces)
Issue #79
1 x Ship's boat frames (15 pieces)
15 x 200 x 3 x 1mm Ayous wood strip
SkyFire
Postby SkyFire » Mon Jan 16, 2012 6:39 am
Issue #80
2 x 300 x 3 x 2mm Ayous wood strip
10 x 200 x 3 x 1mm Ayous wood strip
10 x Belaying cleat
1 x Boat gunwale, rudder and stern post
Issue #81
4 x Brass strip (100 x 3mm)
1 x 300 x 12mm diameter Ayous wood rod
1 x Bowsprit and mast caps (six pieces)
1 x 300 x 6mm diameter Ayous wood rod
1 x 300 x 5mm diameter Ayous wood rod
1 x Printed plan of the bowsprit
Issue #82
1 x 300 x 4 x 2mm Ayous wood strip
1 x Brown cotton thread (0.5mm diameter)
15 x Rigging dead eye (5mm)
15 x Parrel rib
2 x 300 x 6mm diameter Ayous wood rod
2 x 300 x 8mm diameter Ayous wood rod
4 x Top mast truck
Issue #83
12 x Eyebolt
15 x Rigging block (4mm)
2 x Brown cotton thread (0.8mm diameter)
2 x Pale Brown cotton thread (0.15mm diameter)
SkyFire
Postby SkyFire » Tue Feb 14, 2012 12:27 am
Issue #84
1 x 300 x 8mm diameter Ayous wood rod
1 x Fairlead saddle, foremast top, bibs and trestle-trees (14 pieces)
1 x Printed plan for the foremast
Issue #85
3 x 300 x 2 x 2mm Ayous wood strip
1 x 300 x 4mm diameter Ayous wood rod
1 x 300 x 3mm diameter Ayous wood rod
1 x 300 x 8 x 1mm Ayous wood strip
6 x 200 x 3 x 1mm Ayous wood strip
Issue #86
2 x Brown cotton thread (0.5mm diameter)
25 x brass ring (3mm)
Issue #87
1 x Mainast top, bibs and trestle-trees (13 pieces)
1 x Printed plan for the mainmast
SkyFire
Postby SkyFire » Fri Mar 09, 2012 5:36 am
Issue #88
35 x brass ring (3mm)
10 x Parrel rib
8 x 200 x 3 x 1mm Ayous wood strip
Issue #89
5 x Rigging block (5mm)
Issue #90
1 x 300 x 3 x 2mm Ayous wood Strip
25 x Rigging truck
4 x 200 x 3 x 1mm Ayous wood strip
1 x Mizzenmast top, bibs and trestle trees (7 pieces)
1 x Flagstaff support
1 x Printed plan for the mizzenmast
Issue #91
25 x Eyebolt
1 x Gaff jaws
1 x Printed plan for the rigging
SkyFire
Postby SkyFire » Thu Apr 19, 2012 2:51 am
Issue #92
25 x Rigging truck
Issue #93
25 x Rigging truck
Issue #94
5 x pulley block (4mm)
Issue #95
1 x Spritsail course
1 x Spritsail topsail
1 x Mizzen topmast staysail
SkyFire
Postby SkyFire » Wed May 16, 2012 8:02 am
Issue #96
1 x Fore topmast staysail
1 x Jib sail
1 x Mizzen staysail
Issue #97
1 x Fore course
1 x Fore topsail
1 x Fore topgallant sail
Issue #98
1 x Main topgallant staysail
1 x Main topmast staysail
1 x Main staysail
Issue #99
1 x Main course
1 x Main topsail
1 x Main topgallant sail
1 x Replacement riggin plan (N)
SkyFire
Postby SkyFire » Mon Jul 09, 2012 4:15 am
Issue #100
1 x Jack flag
1 x Ensign flag
1 x Mizzen topsail
1 x Mizzen Course
~ End ~
SkyFire
Return to General discussions
