Jerry's 2nd McLaren
Jerry's 2nd McLaren
Jerry's 2nd McLaren
Postby kryten2b » Fri Sep 02, 2011 1:37 pm
Hi, I tried to do this one when De-Ag started & then cancelled this model a couple of years ago - i hope it goes full term this time :x
I have been doing this one for a while now, so thought i would start with a brief catch-up of parts 1-18 ;)
After that I'll post more regularly
kryten2b
Re: Jerry's 2nd McLaren
Postby Paul » Fri Sep 02, 2011 1:44 pm
Hi Jerry,
Firstly great you've also started this build diary as well :)
Whilst I'm not doing this model, I think that they've said it can be built as is, or modded.
What are your views/comments on that?
Postby kryten2b » Fri Sep 02, 2011 2:54 pm
I have seem some beautiful mod work being done with carbon decals over on the official De-Ag forum, but so far i have kept mine pretty standard.
I have to say, the detail on the model is pretty good - so not had the 'need' so far - but that may change, depends how detailed the engine is :D
kryten2b
Postby Paul » Fri Sep 02, 2011 3:21 pm
kryten2b wrote:I have seem some beautiful mod work being done with carbon decals over on the official De-Ag forum, but so far i have kept mine pretty standard.
Hi Jerry,
I think that Julian has done the same as you with the Mclaren, yet Julian will normally mod things if he doesn't think that they are right, so I think that you are in very good company here ! :D
Postby kryten2b » Fri Sep 02, 2011 3:45 pm
Thanks Paul - good to know, i'll keep an eye on Julian's McLaren & get some tips if he decides to mod the engine ;)
kryten2b
Postby Paul » Fri Sep 02, 2011 5:30 pm
kryten2b wrote:Thanks Paul - good to know, i'll keep an eye on Julian's McLaren & get some tips if he decides to mod the engine ;)
Hi Jerry,
Knowing Julian & Aston's they'll both try to get you to build a Cat (XKE Jaguar Coupe thread)! :D :lol:
Postby kryten2b » Fri Sep 02, 2011 5:52 pm
Hi Jerry,
They can try, but i have SEWS (Severe Empty Wallet Syndrome) at the moment, so won't be investing in any new toys :(
kryten2b
Postby Paul » Fri Sep 02, 2011 6:00 pm
kryten2b wrote:
Hi Jerry,
I love that one Jerry ! :)
I'll have to remember that one ! :lol:
Postby Julian » Fri Sep 02, 2011 10:22 pm
SEWS.....Hmmmm yep that about sums it up.....
Timmy Mallet
Postby kryten2b » Sat Sep 10, 2011 9:14 pm
Part 19:
Just a case of inserting the centre rotor pin & attaching the faceplate to the rear upright- no extra limbs required this time :lol:
kryten2b
Postby kryten2b » Sat Sep 10, 2011 9:16 pm
Part 20:
Apologies this is turning up at the same time as 19 - just didn't have time to upload the pictures before now. :oops:
Just a bit of carefully applied SG & a bearing - tricky :o
kryten2b
Postby Julian » Sat Sep 10, 2011 9:18 pm
Keep it up Jerry, more great parts to come.
Timmy Mallet
Postby kryten2b » Sat Sep 10, 2011 9:20 pm
Thanks Julian - I received 21-24 in the week. I just have to try & restrain myself & only do 1 a week, otherwise I'll end up with nothing to do for 3 weeks :roll:
I see you have completed up to 24 - looking good :D I assume you are not planning any engine mods then?
kryten2b
Postby Julian » Sat Sep 10, 2011 9:25 pm
No Jerry, This is an "as is build."
what with the Tiger as is
db5 heavily MODDED
E-Type Heavily MODDED
and now the Hood.... New to wooden partworks so it'll be a MAJOR learning curve
Timmy Mallet
Postby Paul » Sun Sep 11, 2011 4:54 pm
Julian wrote:No Jerry, This is an "as is build."
db5 heavily MODDED
Perhaps I should have started with this rather than the DB5 ......
Postby Julian » Mon Sep 12, 2011 12:22 am
db5 heavily MODDED
NO NO NO NO NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This complete build is held together with abs glue.... tiny screws, and LOTS of S U P E R G L U E
Timmy Mallet
Postby Paul » Mon Sep 12, 2011 8:16 pm
Julian wrote:
Paul wrote:Perhaps I should have started with this rather than the DB5 ......
abs glue and tiny screws I could probably cope with, but the SG ..... :shock: :lol:
Postby Julian » Mon Sep 12, 2011 8:25 pm
Snaps has a McLaren, and the Tiger up for grabs...... Takers Paul., And I have Issue 1 of the Hood spare.....LOL
Timmy Mallet
Postby Paul » Mon Sep 12, 2011 8:46 pm
Julian wrote:Snaps has a McLaren, and the Tiger up for grabs...... Takers Paul., And I have Issue 1 of the Hood spare.....LOL
first up a bucket of sand... Now where's my head :roll:
second one of Chill's "special" green cocktails :roll:
thirdly buy up loads of shares in glue companies before I start, and ERgh....
I need to get a job again first :(and then I'd be up for at least one of them :) :) :)
Postby kryten2b » Thu Sep 29, 2011 5:16 pm
Part 21 & 22 The Engine:
I decided to combine 21 & 22 into one post As they are all part of the engine. Just needed to be careful to glue the parts to the engine block, not fingers & as always, lubricate screws with Vaseline before use :laughing-rolling:
kryten2b
Return to Build diaries
