Bare-Metal foil
General modelling hints, tips, and techniques. Use of glues, paints, etc.
Please keep one topic per thread, and no long rambling conversations here (You know who I mean LOL)
Bare-Metal foil
Bare-Metal foil
Postby Mustang » Mon May 25, 2015 8:32 pm
A simple step by step on using the Bare-Metal foil.
So to start with I just cut a piece out bigger then the area to be covered, and then gently laid it in place. This was then pushed into place with my finger and then rubbed gently with a smoothed of cocktail stick.
Then a second piece was laid into place.
Then a third piece, as you can see the corner ripped as its a tight corner.
So I cut this piece out along the panel line.
Then just added another piece.
The finished results.
This is what I used.
The true metal was used on the nosecone area.
Re: Bare-Metal foil
Postby casper » Mon May 25, 2015 9:25 pm
Nice tips for Bare metal foil mustang :) I use gold leaf glue in some areas brushed on thinly
Re: Bare-Metal foil
Postby Mark » Mon May 25, 2015 11:36 pm
Great tips Mustang. I assume you cut along each panel line after adding each piece ?
Re: Bare-Metal foil
Postby Mustang » Tue May 26, 2015 7:23 am
Hi Mark.
It depends on the panel in question, as this was a curved area I found it easier to do each panel as a separate panel and yes cut along the panel lines.
But with flater areas it's possible to cover them with a larger piece of the foil. So like areas of a plan the stabilisers, tail fin and ailerons could be done as a one piece.
It just depends on how confident you feel when covering the area, but if you make a mistake just cut the foil long the panel lines and remove the damaged part and then add a new piece. :)
Return to Modelling Know-how
