HO Faller fairground
Re: HO Faller fairground
Postby royjess » Mon Apr 30, 2018 8:47 pm
I was going to start on my Ferris wheel that Jess got me for Christmas
ImageSAM_6173 by Roy Lee, on Flickr
ImageSAM_6174 by Roy Lee, on Flickr
ImageSAM_6178 by Roy Lee, on Flickr
I didn't get far as I wanted to illuminate the ride and I needed to fit the appropriate electrics for it at the start of the build. The electric bulb kits for these are an optional extra, so I've now got these on order. So I will return back to this one soon
So I turned my attention to the other kit that Jess got for me for my Birthday last year. Its a sweets and balloon booth
ImageSAM_6180 by Roy Lee, on Flickr
Making a start
ImageSAM_6184 by Roy Lee, on Flickr
ImageSAM_6186 by Roy Lee, on Flickr
ImageSAM_6187 by Roy Lee, on Flickr
Only 25% built
To be continued....
Postby royjess » Sat May 26, 2018 8:48 pm
My Ferris wheel lights arrived so I could continue with that.
The wheel was wired up and then fitted together
ImageSAM_6296 by Roy Lee, on Flickr
Getting there
ImageSAM_6298 by Roy Lee, on Flickr
Now my attention turns to the gondolas
ImageSAM_6299 by Roy Lee, on Flickr
To be continued...
Postby royjess » Sun Jun 03, 2018 7:30 pm
All the gondolas now finished
ImageSAM_6322 by Roy Lee, on Flickr
The pay booth now finished and there was no provisions to illuminate it, so I drilled a hole in the base and fitted a plastic tubing to accommodate a bulb and it's wire
ImageSAM_6325 by Roy Lee, on Flickr
I didn't glue the roof to the pay booth in order to service the bulb at a later date.
Ferris Wheel now finished :dance: :dance: :dance: :dance: :dance: :dance:
ImageSAM_6326 by Roy Lee, on Flickr
All the gondolas are illuminated too, model now stored away waiting for me to build a display case and diorama.
Postby Mark » Tue Jun 05, 2018 2:12 am
Very impressive Roy. Does the wheel rotate (slip rings for the power?) or is it static.
Postby royjess » Tue Jun 05, 2018 7:37 am
The wheel does rotate as seen in the above video. The motor is housed in a little booth sat behind the wheel. The motor has a rubber drive wheel attached to it which the big wheel sits on.
ImageUntitled 5 by Roy Lee, on Flickr
The axle of the wheel are metal. These are electrified. There is what looks like fuse wire going from the axles to metal rivets that are attached to the main wheel.
ImageUntitled 9 by Roy Lee, on Flickr
ImageUntitled 1 by Roy Lee, on Flickr
The gondolas have metal pins which are used to attache to the main wheel, both of which allows the gondolas to swivel as well as electrify the lights in each of the gondolas.
ImageUntitled 2 by Roy Lee, on Flickr
Postby wingnut2 » Tue Jun 05, 2018 3:56 pm
Hi Roy, nice model ! :clap: will you add fair ground music to your diorama ? now that would make a great you tube vid ?
Postby casper » Wed Jun 06, 2018 9:52 am
That's brilliant Roy :clap: perfect speed and quiet unlike the Lego wheel :)
Postby royjess » Sat Jun 09, 2018 8:16 pm
Thanks Casper
Postby Mark » Wed Jul 25, 2018 5:58 am
Very ingenious way of getting power to the moving parts. Those kits have always fascinated me, but I've never built one.
Postby royjess » Thu Jul 26, 2018 9:15 am
Some of the working with some of the models are very ingenious how they work. They are pricey models, can be tedious to build and some of them takes some tweaking to get them to work, but they are worth it :D
Postby royjess » Fri Aug 17, 2018 9:45 pm
Back to the sweet and balloon booths.
Sawdust was put in the popcorn case to represent popcorn. Pink cotton wool was use to represent candy floss. Also the sweet display cases were glued to the counter top.
ImageSAM_6738 by Roy Lee, on Flickr
The heart shape candy was added along with other details
ImageSAM_6761 by Roy Lee, on Flickr
This booth now finished
ImageSAM_6760 by Roy Lee, on Flickr
ImageSAM_6759 by Roy Lee, on Flickr
Also the balloon booth and clown seller came with this kit. The basket and balloons had to be made up and glued together.
ImageSAM_6757 by Roy Lee, on Flickr
Postby royjess » Tue Dec 17, 2019 11:52 pm
Today I finally found some time to build a Faller kit that my wife got me for last Xmas.
Mause Stadt which translate to Mouse City
The Box
ImageIMG_2432 by Jess Lee, on Flickr
The contents
ImageIMG_2434 by Jess Lee, on Flickr
Started to build it
ImageIMG_2435 by Jess Lee, on Flickr
ImageIMG_2437 by Jess Lee, on Flickr
ImageIMG_2438 by Jess Lee, on Flickr
getting there
ImageIMG_2439 by Jess Lee, on Flickr
Now the lorry part of the attraction
ImageIMG_2441 by Jess Lee, on Flickr
ImageIMG_2443 by Jess Lee, on Flickr
ImageIMG_2445 by Jess Lee, on Flickr
The finished build
ImageIMG_2446 by Jess Lee, on Flickr
ImageIMG_2447 by Jess Lee, on Flickr
So what fairground attraction is it? :think:
I googled it and it is a real attraction. :think: But it's not what I thought it was, no not a fun house :think:
Its what is say's on the tin as so to speak, the guest pay to see a whole load of live mice living inside behind a glass.
http://www.xn--die-musestadt-ffb.de/
http://www.xn--die-musestadt-ffb.de/sta ... %C3%A4use/
Postby casper » Wed Dec 18, 2019 2:33 am
Great kit Roy :) Mouse heaven :lol:
Looks just like the real thing
Postby royjess » Tue Dec 24, 2019 9:18 pm
Thanks Casper
Moving on to my next Faller kit, again a Christmas present from last year, just only found time over the last few days to build it
This one is just a XXL Fries Food booth
ImageIMG_2450 by Jess Lee, on Flickr
ImageIMG_2451 by Jess Lee, on Flickr
ImageIMG_2452 by Jess Lee, on Flickr
ImageIMG_2453 by Jess Lee, on Flickr
ImageIMG_2454 by Jess Lee, on Flickr
ImageIMG_2455 by Jess Lee, on Flickr
ImageIMG_2456 by Jess Lee, on Flickr
ImageIMG_2457 by Jess Lee, on Flickr
ImageIMG_2458 by Jess Lee, on Flickr
ImageIMG_2459 by Jess Lee, on Flickr
ImageIMG_2488 by Jess Lee, on Flickr
ImageIMG_2492 by Jess Lee, on Flickr
ImageIMG_2493 by Jess Lee, on Flickr
Postby royjess » Tue Apr 07, 2020 9:14 pm
Today I made a start on the Carousel Bar
ImageIMG_3047 by Jess Lee, on Flickr
The base being made up and adding the decor
ImageIMG_3048 by Jess Lee, on Flickr
ImageIMG_3049 by Jess Lee, on Flickr
Adding the bottles, glass ash trays and glass drinking tankers
ImageIMG_3050 by Jess Lee, on Flickr
No to build the roof
ImageIMG_3051 by Jess Lee, on Flickr
Adding the lighting strips to the underside of the roof, these don't really light up
ImageIMG_3052 by Jess Lee, on Flickr
Adding the decor to the edge of the roof
ImageIMG_3054 by Jess Lee, on Flickr
To be continued...
Postby royjess » Sun Apr 19, 2020 8:10 pm
The rest of the roof canopy edging took a good couple of hours to complete
ImageIMG_3063 by Jess Lee, on Flickr
ImageIMG_3064 by Jess Lee, on Flickr
Adding the support pillars, the drinks price list board and advertising boards to the underside of the roof.
ImageIMG_3065 by Jess Lee, on Flickr
The roof glued in place and the canopy cones are just placed on top without gluing to allow lighting to be fitted.
ImageIMG_3066 by Jess Lee, on Flickr
To be continued...
Postby Morris » Sun Apr 19, 2020 9:48 pm
All cool stuff Roy
1/48 Tamiya Mig 15
Postby royjess » Sat Apr 25, 2020 5:57 pm
Thanks Morris
Today I manage to finish off the carousel bar
The bar stools and tables need to be made up. I had to marry up these fiddly tiny pieces
ImageIMG_3109 by Jess Lee, on Flickr
ImageIMG_3110 by Jess Lee, on Flickr
There were 18 of these in total
and 4 tables
ImageIMG_3113 by Jess Lee, on Flickr
ImageIMG_3112 by Jess Lee, on Flickr
ImageIMG_3108 by Jess Lee, on Flickr
This particular kit is now finished, I will add people when I add this to a diorama at a later date
ImageIMG_3114 by Jess Lee, on Flickr
ImageIMG_3115 by Jess Lee, on Flickr
I've another Faller fairground booth diary coming soon
Postby Morris » Sat Apr 25, 2020 6:51 pm
Like watching all these come together...!
1/48 Tamiya Mig 15
Postby Mark » Mon Apr 27, 2020 10:40 am
You must have a lot of patience to do all the tables and chairs! Looking very nice!
Return to Railways
