DARJEELING HIMALAYAN RAILWAY 7MM
Postby MODENAMAN » Sat Jul 11, 2015 11:17 am
After seeing this incredible and very old railway on TV documentaries - I am going to have a go at a 7mm scale model layout, 1/43rd scale. It is narrow gauge and has 2 foot gauge track. Modelling it in 7mm/foot it can run on 00 track (16.5mm gauge) as a compromse, but I have decided to be accurate and hand build 14mm track ( sadly not commercially available easily ), though I may contract out the building of the points - they are a challenge.
Just got a brass waggon kit to test the water, plus a brass locomotive kit to do afterwards- early days as I am new to brass kits.
Will update as things progress.
MODENAMAN
Re: DARJEELING HIMALAYAN RAILWAY 7MM
Postby chill » Sat Jul 11, 2015 11:27 am
Excellent. Look forward to seeing your new project grow.
Postby Mark » Sat Jul 11, 2015 4:08 pm
Now that sounds a real challenge ! Looking forward to seeing this one :D
Postby Swordfish Fairey » Sun Feb 21, 2016 11:43 am
Hi!, have you seen this?............... http://cp.c-ij.com/en/contents/CNT-0011220/index.html
May give you some ideas................I fancy trying one converted to Plasti-card with some sort of chassis...................Tony
Be yourself........Everyone else is taken....
Tony
Swordfish Fairey
Postby Sojourner » Sun Feb 21, 2016 2:10 pm
Swordfish Fairey wrote:Hi!, have you seen this?............... http://cp.c-ij.com/en/contents/CNT-0011220/index.html
Wow, thanks, Tony - as a paper modeller this is right up my street - I have downloaded some free patterns on other sites, but not come across this one before.
Another project in the stash!!
Howard
Building: Hachette Flying Scotsman,Micromodels Old London Bridge, plus several others started.
Stash: Hachette Mallard, more Micromodels, loads of other stuff
Sojourner
Return to Railways
