baby Jaguar E-Type
Re: baby Jaguar E-Type
Postby Paul » Sun Nov 27, 2011 12:53 pm
baby_astons wrote:can't wait to take one of the cats apart that I've bought damaged -
just for size comparison now that the engine is 10 millimeters higher than before...
should be all very straight forward job now with the build btw -
ooooohhhm wish I wouldn't say such things, it's always drama and work when I say such things :mrgreen:
need to work on the v12 now as this one is getting along.......................................
I'm sure you'll find something else to Chop Aston's :)
Postby baby_astons » Sun Nov 27, 2011 11:51 pm
for once I'm not replying on someone's thread but here -
a pretty funny feeling have to say :mrgreen:
I figured most of the work that needs to be done in order to assemble the body prior to painting AND prior to making the interior -
it's a lousy job but I'm not complaining, just a kind of project management or you get stuck...
as I've cut out the hatch I have another access port for the internals, also the rear end needs to be beefed up,
I'm very unhappy about the weak point of the kit - the join line where the rear and front internals come together,
so this'll be fixed as well - and while working there, also including the rear suspension that will be made including working springs,
after all, I'm into building also a roadster (maybe a second V12 TWR racing) and that needs to take the load without the help of the roof...
and without the typical sagging doors of all roadsters...
Postby casper » Mon Nov 28, 2011 2:37 am
baby_astons wrote:for once I'm not replying on someone's thread but here -
Hi astons :)
are you going to strengthen the joints with extra styrene.
I noticed with mine that the panels have a slight twist and you have to apply a lot of pressure to bring them in line. hopefully it will be ok when glued to the firewall.
I read somewhere that the roadster was heavier than the coupe because of all the extra bulk for strength even with no roof.
Postby baby_astons » Mon Nov 28, 2011 10:15 am
most roadsters are heavier, yes...
I will deffo make some extra "panels" at the back axle to aid the structure,
it's a joke how the inner pan and the boot bottom join -
you could even be able to look through the gap :shock:
it would have been only one clever plastic part that would have solved the trouble, revellogram didn't do that,
instead changed the rear axle and the bonnet hinge retainers - product development, haha...
I even thought of screwing the (original) panels together and to a back plate -
the join lines need to be polyestered anyhow so that would hide the screw heads...
Postby casper » Mon Nov 28, 2011 1:16 pm
baby_astons wrote:most roadsters are heavier, yes...
great idea screwing the panels together astons, i think it's to late for me to make such changes and far beond my skills. i could put in some more contact points using styrene maybe this would help. I notice the join on mine is not too bad. A little gap but as it has a slight twist and that puts stress on the join. :think:
Postby baby_astons » Tue Nov 29, 2011 1:55 pm
have started making the missing undertray part at the front of the rear axle -
should do a pattern for future models (and interested parties ;) ),
hope it'll beef up the body and also help supporting the roadster...
as I am doing new engine mounts (getting rid of the 4 ugly sticks poking out of the engine sides),
this will allow for making the front space frame before painting the body,
so all will be done in one big sweep...
worked out how to insert the finished internals AFTER the body has been assembled and painted -
now it just needs to work out according to my plans :mrgreen:
as you'd imagine it'll be (again :mrgreen: ) a nice chop job...
Postby Paul » Tue Nov 29, 2011 10:33 pm
baby_astons wrote:have started making the missing undertray part at the front of the rear axle -
Hi Aston's,
what is your current plan for beefing up the body, especially re: the roadster?
Postby baby_astons » Wed Nov 30, 2011 3:15 pm
the part I'm currently making should be what I need to "repair" the coupe and keep the roadster straight...
Postby Paul » Wed Nov 30, 2011 3:18 pm
baby_astons wrote:the part I'm currently making should be what I need to "repair" the coupe and keep the roadster straight...
Hi Astons, sounds very good :D so what are your plans on this?
Postby baby_astons » Wed Nov 30, 2011 3:38 pm
finish and make a pdf drawing so everyone can download it and try how it works ;)
Postby casper » Wed Nov 30, 2011 3:47 pm
baby_astons wrote:finish and make a pdf drawing so everyone can download it and try how it works ;)
:D look forward to seeing it m8.
Postby Paul » Wed Nov 30, 2011 3:54 pm
Heck......
Me to try and work things out .....? :roll: :roll: :roll: :)
Postby baby_astons » Sun Dec 11, 2011 4:08 pm
:D this is why I am trying to work things out paul,
so you just need to copy/paste after I sorted the mess here -
still not finished yet, lots of work before xmas in the job and at home, little time for modelling/taking piccies -
BUT still it's coming along nicely, hope to be able to finish soon -
it's a bit of what casp has done, just on a bigger scale ;)
Postby shaneysquarepants » Sun Dec 11, 2011 5:37 pm
baby_astons wrote::D this is why I am trying to work things out paul,
Cant wait to see what you are doing astons. I have also been very busy lately m8, lots to do for christmas and not much time for modeling but i did manage to get the body glued on the Cat.
shane was signed in... :oops:
shaneysquarepants
Postby casper » Sun Dec 11, 2011 5:40 pm
thats better...signed in now :oops:
shane normaly uses his notebook
Postby baby_astons » Wed Dec 21, 2011 7:27 pm
oh cruel world :mrgreen: -
got a large parcel today from a friend =
contents: a red and a yellow e-type, both probably complete kits :shifty:
Postby Julian » Wed Dec 21, 2011 7:49 pm
I hate you.....lol
Timmy Mallet
Postby Paul » Wed Dec 21, 2011 8:31 pm
baby_astons wrote:oh cruel world :mrgreen: -
2 tone Cat coming up .....! :shock: :lol:
NB Aston's, you'll have to tell everyone the info that you sent in the PM re: possible variations for all of the (vaguely) complete ones that you have ! :)
Postby baby_astons » Wed Dec 21, 2011 8:35 pm
:laughing-rolling: :violin:
Postby Paul » Wed Dec 21, 2011 9:33 pm
baby_astons wrote::laughing-rolling: :violin:
Will the Cat that you referred to in the PM, be The Cat That Crept In ...... :lol:
Return to E-Types
