Paul's (Browns Lane Beast) XK E Coupe (E-Type) Jaguar
Re: Paul's (Browns Lane Beast) XK E Coupe (E-Type) Jaguar
Postby Julian » Tue Oct 11, 2011 11:03 pm
oh noooo not Dr. Paul
Timmy Mallet
Postby Paul » Wed Oct 12, 2011 10:02 am
baby_astons wrote:how's QQM -
did she get her limb glued again? :auto-ambulance:
She's had metal pins put in so no :superlglue: :)
Postby Paul » Wed Oct 12, 2011 10:26 am
Julian wrote:oh noooo not Dr. Paul
Heck I hope not ! :shock: Though I might have to send the QQM over to Dr Astons to get her leg modded properly ! :lol:
Postby Paul » Thu Oct 13, 2011 3:44 pm
I've just "cleared the decks" so it's on to doing a leather job on the other door panel....... :roll: :)
Postby Paul » Fri Oct 14, 2011 5:19 pm
Paul wrote:I've just "cleared the decks" so it's on to doing a leather job on the other door panel....... :roll: :)
Hum, I started this yesterday and realised that I cut the leather a bit too short, so I've had to stretch it a bit on the next :superlglue: & hope that then it will be all ok ...... :roll:
Postby Paul » Wed Oct 19, 2011 5:06 pm
The :superlglue: job was fine, but I've still not finished the door panel off :oops:
Postby Paul » Sun Oct 30, 2011 3:24 pm
Paul wrote:The :superlglue: job was fine, but I've still not finished the door panel off :oops:
Heck,
I've not done anything on the Cat now for over 10 days :oops:
Hopefully I'll finish off the DB5 drivers door panel this week, so I can get back on the case !
Postby casper » Sun Oct 30, 2011 5:32 pm
Heck,
Can you think of any more fantastic accessories Paul like the golf cart or back pack. They are superb m8. Would love to see more. :D I have a great fire extinguisher that is from a doll house I may modify.
Postby Paul » Sun Oct 30, 2011 5:46 pm
Hi Casp,
re: any accessories - is that for the Cat or the DB5?
Postby casper » Sun Oct 30, 2011 5:48 pm
Paul wrote:Hi Casp,
for either matey. how are you geting on with nelly paul
Postby Paul » Sun Oct 30, 2011 6:02 pm
casper wrote:
Paul wrote:Hi Casp,
Hi Casp, Little Nellie is on hold at the moment, as I'll need to poly cement a bit that I broke :oops:
I'll start a new post on the DB part of the forum about the accessories - not too sure what we can do that way with the Cat ...... yet! :)
Postby casper » Sat Nov 12, 2011 4:02 pm
Paul wrote:
Paul wrote:Well, I got a bit bored tonight, so here are a couple of pics of the back of the Cat that I've done a carpet job on......
I think that a lot of trimming will need to be done before any fitting, but I think that it's always better to put more on, rather than trying to add extra at a later date:
I've had a look back on the above and think that I'll leave it as is, as I don't wont to mess it all up
Hi Paul,
You did a great job on the carpet m8 :) ,
:?: At what end did you start to glue the leather down. The reason i ask is when i get to the wheel arch i have a fold near the bottom and dont really want to cut it if i can help it.
Postby Paul » Sat Nov 12, 2011 4:26 pm
Oh heck Casp I think that I started at the flatter end.....
I glued that in position first, and thought that if I couldn't stretch the carpet enough, then I could have done the wheel arches separately.
But as it happens, it was then fine to stretch over.
NB - I did need the glue on the base to almost set first before doing the above.
I hope this helps :)
Postby casper » Sat Nov 12, 2011 6:20 pm
Paul wrote:Oh heck Casp I think that I started at the flatter end.....
cheers paul, I managed to get the leather to stretch without cutting :D
Postby Paul » Sun Nov 13, 2011 12:22 pm
Nice one Casp! :D
I look forward to seeing the Pics :)
Postby casper » Tue Nov 22, 2011 8:36 pm
Hi Paul
whats next for your cat build m8.
Postby Paul » Wed Nov 23, 2011 8:08 pm
casper wrote:Hi Paul
Hi Casp,
It's prob on hold until after Christmas, what with work & the Xmas comp etc, I'll only being modding at the weekends for a bit.
Prob over Christmas I read though both your & Julian's build to do a batting order .......
I'm trying to put any spraying off for as long as possible ! :oops:
Postby baby_astons » Sat Nov 26, 2011 6:56 pm
spray chicken :oops: :mrgreen:
Postby Paul » Sat Nov 26, 2011 6:59 pm
baby_astons wrote:spray chicken :oops: :mrgreen:
After what I've done with the Xmas DB5 ......... You'd understand ! :oops: :)
Postby casper » Sat Nov 26, 2011 8:23 pm
you would be fine m8,
if you make a mistake just sand it and do it again.
I have had to do the doors again, i thought they were dry and lay them down and just the weight of them made a few marks in the paint finish. Just a light sand and quick re-coat and good as new. :)
not looking forward to the joins on the body. the front was bad enough. you just have to go for it though and hope you get it right first time.
I have not done anything on the Herald yet. Too busy at the moment. Looks a great little kit though.
Return to E-Types
