Johns(r2d2) Revel Jag build
Re: Johns(r2d2) Revel Jag build
Postby R2D2 » Sat Apr 11, 2015 1:43 pm
Pic of Alfa dashboard
Postby R2D2 » Thu Mar 23, 2017 10:30 pm
Have actually got round to doing a bit ore to my Revel Jag! Made a working hinge for cut out rear boot door! Works quite well but I needed to do a lot of trimming for it to fit!
Postby R2D2 » Thu Mar 23, 2017 10:32 pm
Boot open! Hinge is fairly free and does not touch body work!
Postby R2D2 » Thu Mar 23, 2017 10:33 pm
Front frame, engine, and main body all fitted together!
Postby R2D2 » Thu Mar 23, 2017 10:34 pm
Doors fitted out and painted then covered with leather!
Postby R2D2 » Thu Mar 23, 2017 10:35 pm
Inside window wind mechaism fitted and working!
Postby Mark » Fri Mar 24, 2017 12:09 pm
And there was me thinking that this section was dead ! Nice work R2D2.
Postby R2D2 » Fri Mar 24, 2017 5:23 pm
Thanks Mark! Theres still more to come as Im determined to finish this even though theres a release of the E Type in metal! Front lights fitted! I might fit LEDs in these later!
Postby R2D2 » Fri Mar 24, 2017 5:25 pm
Rear lugage area fitted out including suspension unit! Bars are metal strips bent to shape and glued in!
Rear suspension fitted!
Postby R2D2 » Fri Mar 24, 2017 5:26 pm
Thats it for now but theres more to come.
Postby number1 » Fri Mar 24, 2017 6:49 pm
Very impressed with the work your putting in with the extra details :clap: :clap: :clap:
Postby R2D2 » Sat Mar 25, 2017 7:23 pm
Bit more done to Jag! Painted window frames silver.
Postby R2D2 » Sat Mar 25, 2017 7:24 pm
Rear frame.
Side window frames.
Postby R2D2 » Sat Mar 25, 2017 7:26 pm
Inside roof section painted light gray.
Postby R2D2 » Sat Mar 25, 2017 7:28 pm
Door hinges and plates fitted. They work quite well although I had to be very careful not to get glue on the moving parts.
Postby casper » Sat Mar 25, 2017 8:03 pm
nice work John :clap: :clap:
the metal strips look great in the rear luggage area and you've done an excellent job on the boot door.
Postby R2D2 » Sun Mar 26, 2017 8:33 pm
More work. Glass fitted and rear inside floor glued in place!
Postby R2D2 » Sun Mar 26, 2017 8:35 pm
Rear section. Wheels have yet to be fitted! Only pushed in place!
Return to E-Types
