Johns(r2d2) Revel Jag build
Re: Johns(r2d2) Revel Jag build
Postby baby_astons » Sun Feb 08, 2015 2:46 pm
but you don't need to join to view the pictures of series 1 original cars... ;)
Postby R2D2 » Sun Feb 08, 2015 4:12 pm
Your right! Have had a look and it is helpful! Got some good ideas!
Postby R2D2 » Wed Feb 11, 2015 11:19 pm
More work on the Jag! Steering wheel made from spare Aston Martin parts! Horn switch works as Ive tested it! Might be able to use steering mechanism to steer front wheels but have yet to work out how yet!
Postby R2D2 » Wed Feb 11, 2015 11:23 pm
Rear section fitted with thin rubber and and leather! Chrome lugage slide strips actualy made from metal rod and fitted into drilled holes! Thicker chrome strip is adapted spare Pocher Rolls Royce radiator grill!
Postby R2D2 » Thu Feb 12, 2015 5:16 am
Have now cut out the rear door! It took quite a time but I had an idea to heat a scalple knife with a soldering iron! It worked! Mind you you have to be careful not to apply to much heat! Infact it worked so well you can hardly see the cut marks!
Postby R2D2 » Thu Feb 12, 2015 5:17 am
Door removed!
Door! Im very pleased with the result!
Postby R2D2 » Thu Feb 12, 2015 5:19 am
Internals temp fitted just to see what it looks like!
Postby R2D2 » Thu Feb 12, 2015 5:23 am
Holding door open! Have got to work out fitting a hinge! Have seen pics of real E Types (thanks to baby astons)and its quite big! Should hopefully not be to difficult to produce! Now have a chance to paint the main body parts British Racing Green!
Postby baby_astons » Thu Feb 12, 2015 6:02 pm
I haven't cut the door using heat but mine got out just as well - in fact a series of doors as i did the whole mess for all of my coupe's...
Postby R2D2 » Thu Feb 12, 2015 6:14 pm
Hi baby astons! Glad your rear hatches were easier than mine! :roll: What did you make the hinges from or haven't you done any yet? Have you any photo's of your rear ends! Oo er misses! :lol: I mean rear hatches?
Postby R2D2 » Wed Mar 04, 2015 1:01 am
Hi there! I will have a look mate!
Postby R2D2 » Wed Mar 04, 2015 1:37 am
Hi Bubblewrap! I havent any pistons or other bits but I have got 14 rockers with springs and center rods if your interested! Here's a pic of the bits! I'll send them to you to swap for some other 1/8th bits youv'e got spare! I'll leave it up to you to decide what bits!
Postby baby_astons » Fri Mar 06, 2015 5:06 pm
hi john,
pictures of the hatch story should be on my e-type thread, I haven't yet made the hinges but they'll be brass rod material bent to proper configuration...
Postby R2D2 » Fri Mar 06, 2015 5:27 pm
Many thanks! I'll look on your thread!
Postby casper » Sat Mar 07, 2015 6:10 pm
R2D2 wrote:Holding door open! Have got to work out fitting a hinge! Have seen pics of real E Types (thanks to baby astons)and its quite big! Should hopefully not be to difficult to produce! Now have a chance to paint the main body parts British Racing Green!
Excellent work cutting the boot door out R2 :clap: :clap: :) Have a K matey :clap:
Postby baby_astons » Sat Mar 07, 2015 7:07 pm
...it's the last two pages john...
Postby R2D2 » Sat Mar 07, 2015 7:14 pm
Thanks! I will have a look! And casper! Thanks for the K!
Postby Paul » Sat Mar 14, 2015 1:34 pm
Hi John,
Excellent work on the interior and also the rear door with the hinge!!!!! :D :D :D (K)
Postby R2D2 » Sat Mar 14, 2015 2:49 pm
Thanks for your comments Paul! Its on hold at the moment as I have other comitments but I will start working on it again soon!
Return to E-Types
