Mark's Entry - Male Tank Mk 1
This was a competition for Airfix series 1 kits.
Re: Mark's Entry - Male Tank Mk 1
Postby Mark » Tue May 24, 2011 10:30 pm
I wish I hadn't ! It's a pain, and masking/spraying it was a daft idea. I should have stuck to a paint brush :oops:
Postby Ippy » Wed May 25, 2011 8:46 am
How did you mask it?
If it ain't broke, fix it 'til it is.
Ippy
Postby Mark » Wed May 25, 2011 9:35 am
I used masking fluid. It's mentioned earlier in the thread. Basically, spray it sand, then paint the bits to stay sand with masking fluid. Spray it green and mask the bits to stay green with masking fluid. Finally, spray it brown. Then rub all the masking fluid off. It would probably work well on a larger model, but it didn't work very well with this small model.
Postby Ippy » Wed Jun 01, 2011 10:15 am
I recently found a new way to mask using Blu-Tac. Basicly the same but so much easier to remove.
Ippy
Postby Mark » Wed Jun 01, 2011 10:29 am
Thanks Ippy - I shall give that a try next time I have a difficult masking job.
Postby Mark » Thu Jun 09, 2011 5:15 pm
I've added the tracks and rear wheels now. The tracks wouldn't stay joined using the recommended hot screwdriver, but super glue worked just fine.
Next comes some weathering.
Postby Paul » Thu Jun 09, 2011 5:34 pm
Is this going to be one of this year's Christmas prizes ..... :roll: :)
Return to 2010 Xmas Competition
