number1s Hood
One thread per person, one model per thread please.
number1s Hood
number1s Hood
Postby number1 » Sun Jan 01, 2012 11:09 pm
Thought its about time I started my model of the Hood,
047 (Copy).JPG (82.04 KiB) Viewed 11192 times
Re: number1s Hood
Postby number1 » Sun Jan 01, 2012 11:16 pm
The Keel screwed to a flat board covered in clingfilm so I can remove it later (I hope!)
050 (Copy).JPG (80.77 KiB) Viewed 11190 times
Re: number1s Hood
Postby number1 » Sun Jan 01, 2012 11:25 pm
Baulkheads added, no problems so far
051 [640x480].JPG (75.98 KiB) Viewed 11187 times
Re: number1s Hood
Postby Mark » Mon Jan 02, 2012 2:02 am
Good start No1. Nice to see another build diary :D
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 9:57 pm
Thanks Mark, but disaster lurks round the corner, anyone notice beam 9a not sitting correctly?
Re: number1s Hood
Postby Julian » Mon Jan 02, 2012 10:14 pm
number1 wrote:Thanks Mark, but disaster lurks round the corner, anyone notice beam 9a not sitting correctly?
:banana-gotpics:
Timmy Mallet
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 10:18 pm
Unfortunetly, in my haste frames 5,8 & 9 did'nt end up at 90degrees to the keel, this also caused a problem with the support pieces numbers 30 :(
055 - Copy [640x480].JPG (56.59 KiB) Viewed 11131 times
Re: number1s Hood
Postby Julian » Mon Jan 02, 2012 10:20 pm
Ahhhh
Timmy Mallet
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 10:27 pm
Pic of part 30 not lining up with its slots
059 [640x480].JPG (40.75 KiB) Viewed 11131 times
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 10:34 pm
Solution? I cut through the side piece joining the frames together, pulled the frames upright and glued some scrap wood across the cut, :)
060 [320x200].JPG (24.68 KiB) Viewed 11127 times
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 10:37 pm
Scrap wood glued across gap
061 [320x200].JPG (25.78 KiB) Viewed 11127 times
Re: number1s Hood
Postby Julian » Mon Jan 02, 2012 10:40 pm
must be the frames #1 mine sits fine
Timmy Mallet
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 10:44 pm
Sorted !!!!! :D
063 [320x200].JPG (26.27 KiB) Viewed 11126 times
Re: number1s Hood
Postby Julian » Mon Jan 02, 2012 10:51 pm
Great stuff #1 have a K for sorting it
Timmy Mallet
Re: number1s Hood
Postby Mark » Mon Jan 02, 2012 10:54 pm
Glad you sorted it. Good solution. :)
Re: number1s Hood
Postby number1 » Mon Jan 02, 2012 11:19 pm
Thanks Guys, I'd better pay more attention to what Im doing in the future! :think:
Re: number1s Hood
Postby Mark » Mon Jan 02, 2012 11:56 pm
Happens to the best of us. I had to pull a frame off and re-glue it as it went a bit wonky ! (Don't tell anybody though ;) )
Re: number1s Hood
Postby number1 » Sat Jan 07, 2012 8:41 pm
As i want to R/C my Hood and hope to have all 4 props working I've taken a chance and drilled the 2 holes in frame 37 where I think the inner props will need to pass through, if Im wrong then nothings lost and I can simply glue scrap wood over the holes if needed
cheers Les
001 - Copy [320x200].JPG (18.24 KiB) Viewed 11064 times
Re: number1s Hood
Postby number1 » Sat Jan 07, 2012 8:53 pm
Frame 37 in position showing possible position of inner propshaft.
002 - Copy [320x200].JPG (25.19 KiB) Viewed 11063 times
Re: number1s Hood
Postby number1 » Sat Jan 07, 2012 8:57 pm
The stern completed for the moment, no problems so far :pray:
012 - Copy [320x200].JPG (19.42 KiB) Viewed 11063 times
Return to Build diaries
